Drag Racing Tech
push button ignition
Old Sep 17, 2008 | 04:03 PM
elitopus2002Z's Avatar
Default push button ignition
So years ago when i took out my dash i tweaked the ignition cylinder a bit. Now when i try to turn the car on it throws a security light and wont turn on right away. After like ten tries it fires up. Has anyone done a push button ignition setup? This is a drag car and doesnt sit unattended so im not worried about theft.
Old Sep 17, 2008 | 04:15 PM
BAKED's Avatar
A local guy had a push button setup on his 98 Z28, it worked just fine.
Old Sep 17, 2008 | 04:23 PM
Im assuming i would have to bypass the vats or it wouldnt start without the key?
Old Sep 17, 2008 | 04:24 PM
dlove's Avatar
you need to do the vats bypass
Old Sep 17, 2008 | 05:43 PM
1SlowFormula's Avatar
Is there a write up on the Vats bypass anywhere?
Old Sep 17, 2008 | 06:12 PM
Isnt that done by tuning?
