Drag Racing Tech
A4 guys with the MS3 cam
Old Sep 19, 2008 | 01:16 PM
JASON 77's Avatar
Default A4 guys with the MS3 cam
What would it take to get into the high 10's low 11's on astock cubed, MS3 cam only car? what other supporting mods would be needed, as with what weight reduction is needed? I know there are few here that have done it Matt D, and Camscam02.
Old Sep 19, 2008 | 01:27 PM
SpraydZ's Avatar
I'm still new to the LSx motors, but i was looking into this same setup and this is just what I would assume would get you close to your goals:
4k'ish stall, 3.73 or higher gears, suspension, good tune, LS6 manifold or a FAST if you have the cash.. I'm sure i'm missing some and might even be off.. But that should get you damn close especially with weight reduction like chromoly kmember, and a-arms..
Old Sep 19, 2008 | 03:16 PM
dnkynrbk's Avatar
my old set up set up on a 200 shot 10.11 patriot stage 3 heads performa built 4l60e lv2 3500 stall
Old Sep 19, 2008 | 06:31 PM
mike#9's Avatar
Great run....
To answer the question, it will take a great suspension setup.....great tire.......and tons of weight reduction
Old Sep 20, 2008 | 12:34 AM
camscam02's Avatar
no need for great suspension to go 10.9 cam only, get all the boltons, get the rght converter/gear/tire combo to mad your setup and take out weight. good da is key to going fast.
all i had for suspension was subframes and spohn rear drag bar.
