Drag Racing Tech
Heat Shield on Brake Lines
Old Sep 22, 2008 | 04:12 PM
tee-boy's Avatar
Default Heat Shield on Brake Lines
Removing heat shield that sandwiches brake lines against the frame rail right behind the ABS Block...
Doing ABS Delete.
Anyone remove this shield? Should I expect and problems if I remove it?
Old Sep 22, 2008 | 04:39 PM
DanZ28's Avatar
Is it in your way? I would try to leave it on if you can, keeps the exhaust heat off there. Or you can get some thermal sleeving.
Old Sep 22, 2008 | 06:12 PM
tee-boy's Avatar
makes sense; don't want brake fluid to boil.
wondering if anyone else has any experience w/ this? I just can't stand putting heat shields back on.
