Question on new rear axle
The car is a H/C LT1 that is currently running 11.60 at 115/116 with a best 60ft of 1.61.
are you auto or m6. being an auto i wouldn't go past 3.90, even if you have the taller tire.
the 3.90 or 3.73 will give you more room to trap higher speeds as you increase power levels.
I run 11.61 @116.23 with a 1.599 60'
note your rpms at the end of the track and decide if you have room for a deeper gear.
Another factor is, is this car all strip? or strip/street. I think 3.73 -3.90 is perfect for a strip/street application. But if you spend more time trying to get that best possible number, 4.10 with a taller tire might be the choice.
If left N/A you can even do 4.10/4.11's or w/ power adders, you need to decide what MPH you may cross the traps at and decide accordingly.
The taller tire you run, you can put the psi to a reasonable level but get a better contatch patch vs a smaller tire of the same width.
I am throwing alot of ideas out, but honestly decide what the final power combo is, and what mph you want to run.
