Vengeance Tuned InconTT
Old Dec 4, 2008 | 10:13 PM
VIPERBLUELX's Avatar
Nice numbers man! I'd think the 60lbers would be good for more power though. Could you log fuel pump duty cycle?
Old Dec 4, 2008 | 10:43 PM
1999ssls1's Avatar
Thanks! Im just gonna wire both pumps to run all the time. Im ready to turn it up and tune it to the max. lol
Old Dec 4, 2008 | 10:44 PM
HUNTER02SS's Avatar
I was going to say. Only 600rwhp and the injectors are maxed out?? Something not quite right there? With the proper fuel pumps and fuel pressure you can get atleast another 200rwhp out of them safely!
I would check into the fuel system a little more. Do you have a Fuel Pressure regulator by any chance?
Old Dec 4, 2008 | 10:51 PM
1999ssls1's Avatar
Yeah I have a Boost Referenced FPR and a return. I have twin walbros and the 2nd pump was hooked up to a hobbs switch. I dont believe it was working, so Im gonna just wire them both together.
Old Dec 5, 2008 | 12:01 AM
outtagas's Avatar
i thought you datalogged it after you wired them together?
Old Dec 5, 2008 | 01:09 AM
Formulized94's Avatar
Bad ***, savage. Hope mine makes some power....and doesnt scatter
Old Dec 5, 2008 | 07:55 AM
I've never been a fan of a Hobbs switch on anything fuel related whether it be a pump or a boost controller. If you're worried about burning the pumps up by running them both at full voltage you could always get an Aeromotive voltage controller. Good luck with it I want to see what it does.
Old Dec 5, 2008 | 09:13 AM
1999ssls1's Avatar
I did and it went to 90% duty cycle.
Old Dec 5, 2008 | 09:15 AM
the injectors or the pumps were at 90%?
Old Dec 5, 2008 | 09:16 AM
1999ssls1's Avatar
Im not worried about them burning up. The pumps are supposed to be good for around 100k miles (I think). I dont drive the car enough for it to matter, so I think I'll be ok.
Old Dec 5, 2008 | 09:18 AM
1999ssls1's Avatar
Injectors. Im gonna have to test the pump voltages. Injectors were at 120%
Old Dec 5, 2008 | 02:01 PM
  #32
DeltaT's Avatar
Nice numbers and a cool setup.
Anything over 100% injector duty cycle doesn't really mean anything because they are just sitting there wide open with no cycling occuring.
Jim
Old Dec 5, 2008 | 05:49 PM
  #33
o2ws8's Avatar
Nice numbers! Were those thru a full exhaust? Or do you have cutouts?I have an Incon kit on mine and mine made 744/796 at 12psi with dual cutouts on 55 pound injectors!!!
