Stock LS1 with D1SC
Old Mar 18, 2009 | 08:08 PM
WHPLASH's Avatar
Great numbers. Get that thing to the track, you'll be suprised how it does!!!
Old Mar 18, 2009 | 08:43 PM
Only ERO's's Avatar
Originally Posted by transam69230
My buddy is pretty much running the same combo, but he has the twin intercoolers still, and he is right at the 500hp mark. He is in same boat, he doens't want to push it anymore until he gets a built motor. These stock ls1s with prochargers are a blast to ride in and drive i think.
Eh, they are alright!
What RPM did you make the power at? Dynojet or Mustang dyno?
Old Mar 18, 2009 | 09:27 PM
BigBenz's Avatar
5800 rpm was the peak hp. dynoed was on a dyno jet. waht mods do you have? my first dyno with out the 60s and FMIC was 459 rwhp.
Old Mar 19, 2009 | 12:27 AM
1sicws6's Avatar
I personally think you need a better muffler.. good numbers anyway..
Old Mar 19, 2009 | 06:10 AM
Only ERO's's Avatar
I have an 8 rib D1SC kit. The car was seeing 8 lbs right at 5800 when it was shut off. 2001 car so it has the LS6 intake. It has custom made header and a custom ORY. It had a Loudmouth exhaust but I had the resonator cut out and put a Borla XR-1 in it. Still has a rasping sound which I can't stand. I would rather deal with the sound and spend money elsewhere right now.
I am tempted to have it retuned and bump the rev limiter to 5800 but I also feel this setup is pretty safe. We'll see though.
It didn't take long to wreck the stock clutch. I went with a Spec 3+ and I wish I would have just spent the money to go with a Twin Disk. Next step is a Midwest Fab 9". I wish Eric would run a special on them!!!
Enjoy the Procharged LS1. They are definitely a lot of fun. Everybody on here has burnout but you can show everybody what real burnouts are: rolling burnouts!!
Old Mar 19, 2009 | 06:53 AM
forcd ind's Avatar
your just about at what i made, 488/433, in my 6.0, mild cam and P/P stage 2 heads, D1SC, 8 rib, 9 lbs, with vic jr and carb-in my chevelle, i ran 126 mph with a tight converter, went 10.68 @ 125 with a looser converter(all the gains in the 1/8)
the dyno #'s dont mean a lot, except making changes at the time-seen a lot higher hp cars running slower-would be cool to see some back to back testing with diff converter stalls, see how it affects #'s-i guess it could be done with a converter lockup though
you def have more room to add power, good #'s
Old Mar 19, 2009 | 09:35 AM
BigBenz's Avatar
Sounds right. Your dunno will read low. Be safe on that st co bottom. It will. Blow
Old Mar 19, 2009 | 10:55 PM
02BLKWS6MD's Avatar
A4 or M6? I'm not seeing which it is.
Old Mar 19, 2009 | 10:58 PM
BigBenz's Avatar
m6 the only way to fly
Old Mar 20, 2009 | 12:15 AM
stevied916's Avatar
is it tuned using hptuners or efilive?
Old Mar 20, 2009 | 09:06 AM
BigBenz's Avatar
hp tuners with a SD tune
