What would cause this?
I was just reading a thread on some other site where they were talking about preload:
even with the smallest amount of preload, with high oil pressure, and especially higher RPM where the lifter is getting filled quicker, it has a tendency to overcome some of the spring pressure and leave the valves open
IDK seems interesting... im am running a 10/30 oil right now and oil pressure is like 60+ at 3000 rpm up... im gonna switch to mobile 1 oil and a lighter weight and see if it will help... also waiting on a pushrod length checker.
If my preload is not right then it can be causing some valve float also...
Mine really looks like valve float and alot of experienced people say its valve float. So im gonna try some things and if it doesn't help ill buy some springs.
O ya when i had an sts kit on my ls1 with the garrett T70/.86AR and I didn't seem to have a backpressure problem... but idk, hope it will fix your problem!!!!
