Is my cammed a4 where it should be?
3.23 rear gears
tr224 .561/.561. 112 lsa.
Slp loudmouth II
MTI air lid
stock headers, y, and cats.
Stock stall
347.7 rwhp 337.3 ft lbs of torque
I was told by the shop they are great numbers for stock headers and cats. The run before that made a bit over 350rwhp but it was right at peak and was sacraficing a lot through the powerband.
Also the chart reads by mph not rpm. It cuts out before 145 mph. I had bumped up the redline by 200rpm. Should it have ran further? I have the stock 16 inch wheels and factory tires.
3.23 rear gears
Slp loudmouth II
MTI air lid
Stock stall
What is your shift point/limiter set at?
You should have done a converter before anything.. Since you didn't it would be my next mod no matter what, before manifolds, cutout, anything.
The fuel pump and more tuning got it to 350rwhp but with less power through the whole curve. He showed me those results along with the next tune which peaked at 347.7 rwhp but far more horsepower throughout the curve.
As soon as I get the emailed results of the dyno, I'll put them up. I am pretty sure this guy is reputable. There aren't too many places to go in Oahu to get a tune, so it was either this or a mail order. The shift points are now supposed to be at 6200 rpm.
The guy who tuned my car also said I should go with the stall next, but he had told me that I'll likely see a bigger jump from long tubes and a y pipe than someone would running a stock cam. Is there any proof to back this up? I know most go with bolt ons before the cam, but anyone know of any results?
Headers and a converter will make it a different car which is alot more fun to drive
A full exhaust setup is not going to gain you anywhere near what a converter will gain you and it will cost the same amount of money. Why would you not do a converter first? HP is NOT everything. You are going to have a high horsepower car that sounds mean as **** but runs like a dog. Not something I would want personally.
You will most definitely see more out of LTs/exhaust than a stock or bolt on car would. But everyone always sees the most gains with a converter.
I urge you to get a converter next.
Perhaps I'm failing at looking for a better price on converters, and maybe putting one in is easier than I think.
I just started looking more at other people's dynos, and it occurred to me; if the same two modified a4 cars are dynoed, the one with the higher stall will make a bit less horsepower. Knowing that, I realized why they measure them in mph instead of rpm. Because, on a dyno that measures mph, the amount of torque and horsepower down low is increased DRAMATICALLY.
I had already known a stall makes a bigger difference on an a4 car than a cam or any bolt on can, but now that the numbers make more sense to me, it really clears a lot up. An A4 with a 4000 rpm stall may be a bit more loose and not dyno as high as a stock converter car, but as it's flashing right to 4000 rpm, you are making whatever horsepower or torque numbers you'd normally be making at that rpm(or close to it, it seems?), but at a lower speed. Are my observations correct?
EDIT: I also assume the stall would eliminate the feeling that my car wants to take off on me at a stoplight even when I have the breaks on.
Don't sound too bad, but the stock manifolds and cats are bottling it up a lot. You are right by saying bigger inrease with your cam than with stock cam.
Most bolt on/header/ORY a4 cars I tune lay down at least 350hp 360tq. Its not crazy to say you will pick up at least 20rwhp or more with longtubes.
