owner said it dyno'd @ 399rwhp?
Old Feb 6, 2010 | 09:41 PM
SpecV44's Avatar
Default owner said it dyno'd @ 399rwhp?
I just bought a 2000 Trans Am. The owner said it dyno'd at 399rwhp, but it seems just a touch low. What do you guys think?
2000 Trans Am 5.7/t56 119k (unsure of mileage when dyno'd)
Underdrive pulley
solid tensioner
LS6 intake
stock LS1 heads w/ patriot gold valve springs
longtubes
off road Y pipe
magnaflow catback
5.0 short shifter
7 LED shift light set to 6500
Z06 motorsports wheels
Futral F13 cam 112 LSA
3.73 gears
Slp lid W/ K&N filter
Ported MAF
Ported Throttle body
Spec Stage 3 Clutch
Subframe Connectors
Spohn lower control arms
Old Feb 6, 2010 | 09:56 PM
Nitroused383's Avatar
Sounds about right to me. Local guy had a F14 cam (little bigger than yours) car with fast 90 intake, put down 392 rwhp on the same dyno I did my car on. Not all dynos are the same.
Old Feb 6, 2010 | 10:17 PM
Longshot LCMS's Avatar
You bought that white T/A? I almost picked it up, seemed like a really good deal. It was a little rough around the edges but nothing that couldn't be worked with. How do you like it?
Old Feb 7, 2010 | 07:03 AM
ScreaminRedZ's Avatar
registered user
Sounds right to me also.
Longshot, your car looks sick with those wheels and badges on it!
Old Feb 7, 2010 | 10:11 AM
SpecV44's Avatar
We love it, my wife drives it daily to work.
It needs some work, just changed the oil yesterday, greased the LCA's (I think they need more grease still), perhaps a bushing kit. I need to change to synco-mesh, and change the rearend fluid.
Trying to figure out a squeak/slight bang noise. I know the longtubes are prone to hitting the floor, but I need to figure these things out. I think the sqeak/bang will be remedied by the bushing kit, and I am hoping a heavier gear oil will make the VERY slight whine go away.
Old Feb 7, 2010 | 12:26 PM
BlkBird2000's Avatar
Numbers seem right to me. It just depends on what dyno is used. One might say 399, another 420, and another say 375. Unless you're going to get it dyno'd, just go with the 399. That is more than what mine puts down.
Old Feb 7, 2010 | 02:08 PM
Good, it just needed a teeny bit more work than I wanted to put in. I do remember when I was talking to him about the car he said that it had aftermarket lower control arms and he thought a bushing was going bad. That's more than likely where your squeek is coming from. Look into that.
Another thing I asked when talking about the cam, he didnt install it and doesn't know exactly when it was installed. He believes it was done by the owner prior to the one he got it from, which is some 30k miles ago. What does that mean? Means those valve springs might be reaching the end of their life. Check them out and replace if needed before they let you know in their own 'special' way which result in a lot more carnage!
The banging you could be hearing could be from the Y-pipe hitting the floorpan, try and just change the bushing holding up the trans, that gets rid of it for lots of guys.
In regards to your dyno numbers, I wouldn't be upset with that. 400whp cam only is very good, regardless of how you look at it. That's a good number and an indication that despite the mileage that engine is still healthy.
Old Feb 7, 2010 | 02:10 PM
Thank you, Sir.
Old Feb 7, 2010 | 07:23 PM
SpecV44's Avatar
Thanks bro. I will see about pulling a valve spring off and testing the pressure on it just to be safe.
Anything else you and he talked about? PM me if needed. None of this was mentioned to me, but stupid me I forgot to ask as well, it was 10pm, I had just driven for 2 hours, and was tired lol.
I plan on welding in a o2 bung, throwing my wideband in and doing some tuning myself, since I have HP Tuners on hand. My friend said it was rolling a lot of black smoke under hard acceleration, which leads me to believe it is running super rich under hard throttle (plus friend is a ASE mechanic, and he didnt seem too bothered with the smoke). I also plan on dyno'ing it again here soon, as our local motorsports forum does dyno day's every month or so. just to see what it puts down on their dyno.
I washed the car up today, there are a lot more knicks and scratches than I saw before, but nothing that can be done about it now. Still cant complain for $6800.
Old Feb 8, 2010 | 09:17 AM
02BLKWS6MD's Avatar
That sounds about right for those mods. All dynos read differently but they'll all be within the same range if you had a car with the same mods.
