Dyno Numbers??
Old Mar 30, 2010 | 08:36 PM
bmcfadin85's Avatar
Default Dyno Numbers??
I bought a 98 ss with 60k miles on it back in December from a one owner. I was told it had 353hp to the ground. Here are the mods,
-slp full lenghts
-slp y (cat delete)
-slp lid
-slp elbow
-slp underdrive pulley
-k&n
-flowmaster kit
-air/egr delete
-comp gold rockers
-free mods
-4:10's
-tuned
-80mm TB
I think thats it, does 353rwhp seem like a stretch? I'm having it dynoed friday morning and then friday night Im taking it to the track.
I have been wondering if I'll be disappointed with the numbers so I figured someone on here may have an idea.
Old Mar 30, 2010 | 08:45 PM
ds98formula's Avatar
Sounds high with no LS6 intake but hey lets us know what she has and what she runs
Old Apr 2, 2010 | 05:01 PM
bmcfadin85's Avatar
Ok, slight disappiontment. Took it in to dyno it today, second pull: 335/340. Previous owner must have been cross eyed. It dove at about 5k rpms so I guess I'll go ahead and get a cam and intake. It might have turned out a little better had it not been an 80 mile drive to the shop with zero cool down time. The guy was ready to leave so it was hooked up and ran at running temp.
Old Apr 3, 2010 | 12:45 PM
I wouldnt be dissapointed i put down the numbers in my sig with my mods so you look on track to me.
Old Apr 3, 2010 | 12:50 PM
carzman5678's Avatar
Im made 326/365 with LTs, pacesetter Y, Lid, and LS6 intake, and dyno tune. Auto with 2.73 gears.
Old Apr 3, 2010 | 02:07 PM
Did you end up running it at the track yesterday?
Old Apr 3, 2010 | 06:29 PM
Slowhawk's Avatar
LS1Tech Sponsor
The #'s you got are good for a 98 with the mods listed.The previous owner could of eassilly got 353 on a cold day/uncorrected #'s.
Old Apr 3, 2010 | 06:44 PM
ScreaminRedZ's Avatar
registered user
Yeah, the numbers look good to me. An LS6 intake will give you a nice bump in power for the price.
Old Apr 3, 2010 | 06:48 PM
LS1 bird's Avatar
Get track results that's what will tell u if its slow or not.My 02 a4 formula 12.6 at 110mph.Full bolt ons full exhaust ls6 intake.
Old Apr 3, 2010 | 07:47 PM
bmcfadin85's Avatar
Track was closed due to rain so I'll have to wait till next friday.
Old Apr 3, 2010 | 08:23 PM
fccs's Avatar
You got pretty good numbers there what are you upset about? Did he say what type of dyno it was, maybe he dynoed on a dynojet and you on a mustang so it came up lower. And you basically just have headers back exhaust.. so 330rwhp-350rwhp is in the correct range. With a dyno tune and ls6 intake you will hit 350-360ish.
Old May 30, 2010 | 02:33 PM
bmcfadin85's Avatar
Ok, its been a while since the car was down. I did a head and cam swap along with a bbk intake and tune. I finally took it to the track last night. I ran 4 times and my best was 13.1 @ 112.
Aside from not hooking up with sumotomo rears my clutch seemed to sick everytime I tried to hit 4th. Anyone know what might by causing this? I know the clutch is fine and it has less than 10k miles on it. It stuck every run when from 3rd to 4th. I would pull it out then push it in again to get forth after that it would pull hard the rest of the way.
Old May 30, 2010 | 09:11 PM
Slave master cylinder or you may need to do the drill mod as I heard some of these cars have problems hiting gears when running them hard. Search about the drill mod on here and see if that is sounding like that could be you problem. Also what heads and cam did you get and how much power does it have now?
Old May 31, 2010 | 10:08 AM
bmcfadin85's Avatar
I got the stage one heads from texas speed and the cam is a comp 228R, I havn't had it on the dyno yet though. I'm planning on putting it on one next week.
Old May 31, 2010 | 01:29 PM
Ok, well make sure to update this tread when you do. make sure you check out that drill mod.
Old Sep 28, 2010 | 05:46 PM
bmcfadin85's Avatar
Ok, finally got the car dynoed. With an 1.5 hour drive to the shop and only enough cool down time to strap the car down it ran 396/355. I'm taking it to the track friday to see if I can break in to the 12's.
I tried the drill mod but it didn't seem to help much.
Old Sep 28, 2010 | 06:27 PM
RJB01camaross's Avatar
Thhose numbers seem low for that combo, unless its on a stingy dyno. Can you post the graph?
Old Oct 2, 2010 | 02:57 PM
bmcfadin85's Avatar
I dont have a way to download the graph right now.
I think the dyno was off because there was a built newer saleen that only put down 411hp. The owner of the saleen had put down 407 on the same dyno 3 months prior before installing full exhaust, TB, and a smaller pulley.
I ran 12.6 @ 114 last night at the track.
Old Oct 2, 2010 | 04:45 PM
fccs's Avatar
Your times are what I was running with a mail order tune, also gotta remember it's a big difference with street tires vs drag radials. If you cut a 12.6 at 114 on street tires you should easily be a low 12, high 11 if a good lunch car with drag radials. Weather and dyno matter alot when putting down numbers. Realistically every dyno is different and they vary 10-30hp sometimes depending on type of dyno and conditions, it's stupid to see what a car makes by a dyno but track is best way to tell.
You also said you had it dynoed, does this mean dyno tuned or just dynoed? I put down 385/350 untunned on the dyno, still awaiting dynotune for next week to see what everything will do then but yea.
Old Oct 2, 2010 | 05:55 PM
NHRA4MULA's Avatar
you may want to take the rockers off and put the stock ones on that will bump your number up a little thunder racing just did some dyno testing and the stock rockers are better I know its hard to believe but they are alot lighter then any aftermarket rockers
