Why is my torque so low?
Old Jun 10, 2010 | 11:49 AM
GM PHASST's Avatar
Default Why is my torque so low?
I dynoed 310 rwhp and 246 rwtq about three weeks ago. The car has 3" cat-back, longtubes and air lid. Not sure what brands tho. Other than those three mods the car is a stock 99 ls1 camaro w/m6 and 3.42 gears.
With the exhaust cutout plate off the car dynoed 326 rwhp and 195 rwtq and with the air filter and cutout plate off it dynoed 329 rwhp and 190 rwtq.
I know that with the exhaust cutout plate off I would lose low end. But it's like I never had any to begin with.
The drivers side cat has about a 1 1/2"-2" crack in it. Could that be causing the low torque numbers.
I gotta go so I will check back later. Thanx for any input.
Old Jun 10, 2010 | 01:20 PM
Stang's Bane's Avatar
If that is on a dynojet, you need to shut the car down and start doing some trouble shooting. that car is having serious problems.
Old Jun 10, 2010 | 11:31 PM
Paint_It_Black's Avatar
There is something wrong with their dyno. There is nothing wrong with your car.
Here's why: HP = TQ * RPM / 5252
Stock LS1 is rated 310 @ 5200 for hp. So your peak is 5200. Lets say the long tubes etc brought it up to 5400. I'm being generous but making a point. To make 329hp at 5400 rpm, you needed 320 ft/lbs of torque. And your torque peak is not even at 5400, it's a lot closer to the 4000 rpm a stock LS1 makes, where your torque is higher than 320, probably more like 350.
On another note, you don't lose bottom end from long tubes unless they are something ridiculously big for your combo like 2" primaries on a stock motor. A cut out will never lose torque because engines hate back pressure and generally a cutout relieves it (but never adds to it). The less energy spent pumping exhaust gases out, the more energy gets to your rear wheels.
Old Jun 11, 2010 | 01:22 AM
Azrael's Avatar
I tend to agree with Paint it Black, it isn't the car it is something with the way the dyno is computing the torque numbers. It would be impossible to have that low of a torque reading at the RPM a LS1 normally turns at, with that high of a HP rating, since it is a function of specific mathematics formula.
Old Jun 11, 2010 | 02:08 AM
itsslow98's Avatar
how does the car feel on the street? does it struggle or feel fine? if its fine then something is most definetly wrong with the dyno.
Old Jun 11, 2010 | 05:30 AM
BLK02WS6's Avatar
Definitely a dyno issue...
Old Jun 11, 2010 | 10:48 AM
yeah, i got to thinking about it on my way home. Your car should be fine.
I am sorry for the stupid post..
Old Jun 11, 2010 | 12:28 PM
Damian's Avatar
LSX Mechanic
This.
Old Jun 12, 2010 | 12:31 AM
GM PHASST's Avatar
I knew that I wasn't goin crazy. It feels really good in first gear from about 3-5800k or so. Thanks for all the input. I definitely appreciate it.
