Do you think it will break into the 11's?
Old Jun 18, 2010 | 05:42 PM
ExceSSive's Avatar
When my 2002 SS was making 380/376 @ 3520# I ran 12.42 @ 113 with a 2.2 60' with 3600 stall/3.23 gears on street tires. So I think you can get that 11 sec slip with some traction. This run was in Kentucky.
Old Jun 18, 2010 | 06:19 PM
tg580's Avatar
I just bought a G-Tech Pro. I've heard that those are pretty accurate. When it comes in I'll post my times.
Old Jun 18, 2010 | 06:21 PM
odarabla's Avatar
Originally Posted by tg580
The local dragway where I'm at says if you have a convertible and run in the 13's (it might be twelves) that you have to have a roll bar. I just dont think that I am ever going to want a roll bar in my car. I think it might look like **** with the top down.
Well just go and make one pass. Like I said, all they can do is tell you leave after you break the rules but at least you will know what your E.T. is.
Old Jun 18, 2010 | 07:10 PM
tittan1500's Avatar
FYI g tech or not your not going to hit a 11 on the street with your setup... I guess 12.6 at 114 on the street
Old Jun 18, 2010 | 07:21 PM
blk/slvr02ss's Avatar
My car ran 11.88@113 w/1.6360ft w/ 330rwhp so w/that hp and hooking up u should be very close to 11's.
Old Jun 18, 2010 | 10:00 PM
ExceSSive's Avatar
330? was that on a mustang dyno? or a really light car?
Old Jun 21, 2010 | 10:13 AM
tg580's Avatar
I ran the car 4 times with the G-Tech with my buddy in the car also and he weighs 160lbs. 2 times it didn't hook up 12.70's @ 114. The two times it did hook up it went 12.25 and 12.29 at 115.8 and 115.4. What do you guys think?
Old Jun 21, 2010 | 11:58 AM
Detroitmuscle's Avatar
that mph is good for 11s all day but it may be a bit higher because of the lack of traction. On a well prepped track you should be able to drop down to 1.7 60' times no problem and run 11s easily.
Old Jun 22, 2010 | 06:54 AM
LS1 bird's Avatar
The mph is good for high 11's,but that 60ft isn't.If u can get that 60ft to a 1.6 then I say u have a good chance.If not u will see low 12's all day.
