Speed Inc. C6 with A&A kit
Old Sep 21, 2010 | 11:04 AM
LS1 SPEED's Avatar
Default Speed Inc. C6 with A&A kit
This is a car we wrapped up last week for a good customer. ( did his DD 2010 SS headers, corsa and CAI a couple weeks back )
I have to say we are always very pleased with the results of the A&A kits.
C6/A6 Vert
The car came in with CAI, LT's with cats and a Corsa Sport and tuned by someone else. The A/F as you will see was a bit on the lean side.
upgrades :
-A&A w/ V3 Si unit 8-9 psi
-Boost-a-pump
-TR6 plugs
-MSD wires
-Royal Purple oil change
-Speed Inc. dyno tune
The car is on stock wheels and tires and simply gets no traction. I took the customer for a ride and to say he was a bit surprised was an understatement. The tech said he was still excited Sat. when he came back to get the car
There are new wheels and tires on the way which should help to make the car a bit more predictable.
The converter would unlock and relock for some reason and obviously caused the graph to look a little odd.
Old Sep 21, 2010 | 11:13 AM
RJB01camaross's Avatar
How much boost?
Old Sep 21, 2010 | 11:17 AM
LS1 SPEED's Avatar
seeing 8-9 psi
Old Sep 23, 2010 | 10:52 PM
robsquikz28's Avatar
it was that lean originally when you got it in the shop? How much more power did it make after you were done correcting afr? Or did you never run it after you retuned it?
Old Sep 24, 2010 | 07:38 AM
LS1 SPEED's Avatar
it was tuned by someone else and we just did a pre-dyno
We did not re-tune it NA just to make the A/F correct since it was getting the blower and re-tuned accordingly.
a6, aa, c6, kit
