tv.2 cam in ls2 results
I'm looking for more power up top, I would like to get this motor to pull to 7,000 without dipping off...do i just need a bigger cam? or a solid roller cam? Also thinking of the fast 102, but I think that will be 5rwhp if that, any input is welcome I may try to ditch the stock 2 7/8 midpipe for a flowmaster merge and 3in. setup.....
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Honestly, I'd just send your FAST out to Tony Mamo (since he started the whole FAST porting thing) and let him work his magic there. I'd say let him spec you out a cam too, since he can match the flow characteristics of the FAST & those heads with a cam suited for the whole combo. I'd consider letting him massage the heads as well...basically just call & let Tony take over the combo
What's the CR?
This is Sean btw.
Oh and a new cam for the catfish means the Ram can take the T2.
