Guys picking up w. muffler right off headers?
Old Nov 23, 2010 | 06:47 PM
1nastyss's Avatar
Default Guys picking up w. muffler right off headers?
I plan on running about 10-12 inches of pipe then a muffler dumped off each header, are guys picking up or losing HP once they go with this type of setup, my car is a H/C/I setup and im going from the TSP true duals , which i felt flowed very well. Only reason im doin this , is to get clearance for a shorter style torque arm with the cross brace, and the TD's wont clear the crossbrace....Let me know
Old Nov 24, 2010 | 02:52 PM
1nastyss's Avatar
Noone has ran this setup? BS, 51 views and no post
Old Nov 24, 2010 | 02:59 PM
thunderstruck507's Avatar
I predict you not noticing any difference from what you had before.
Old Nov 24, 2010 | 05:00 PM
1nastyss's Avatar
I just don't want to lose any power
Old Nov 24, 2010 | 05:17 PM
NHRAFORMULA00's Avatar
It will not lose any top end,but bottom end (under 3,000) might.Im running bullets off of half of a y pipe,and it screams.It is a drag only car now for the past 2 years or so,thats why i dumped all the xtra weight.
Old Nov 24, 2010 | 07:12 PM
180ls1's Avatar
yea you will be golden, that sounds like the best way to go for you.
Old Nov 25, 2010 | 05:15 AM
butler's Avatar
bullets right off headers. Took them off at the track picked up nothing. I leave them on.
Old Nov 25, 2010 | 01:04 PM
WSsick's Avatar
Aside from a loss of hearing, I doubt you'll see much power loss up top.....which is where it matters since this sounds like a drag car.
Old Nov 25, 2010 | 01:23 PM
k0261886's Avatar
needs an x or h pipe
Old Nov 25, 2010 | 02:38 PM
BADD SS's Avatar
wrong.... not in his application.
Old Nov 26, 2010 | 06:53 AM
john563's Avatar
have you ever had a y pipe? If so what did you gain going from the y pipe to the duals?
Old Nov 27, 2010 | 01:38 PM
1nastyss's Avatar
I had an ORY and a B&B triflo catback, and when i switched to the duals, i picked up like 5-6
Old Dec 1, 2010 | 12:11 PM
00 Trans Ram's Avatar
My race car had Hooker 1.75" LTs with turndowns. No pipes, nothing. Ran just fine. Videos on youtube - search "Hammond Tire" and find the races.
While they may not be "optimal" (they won't take much advantage of scavenging), the lost weight versus an X-pipe and/or full exhaust is well worth it. What do we usually say - 1hp=10lbs. If you lose 5hp, that's worth losing 50lbs.
Plus, a loss of hp only hurts acceleration. A loss of weight helps accel, stopping, AND turning. I'd rather lose 100lbs than gain 20hp ANY DAY OF THE WEEK.
