Dyno Tune ?????
Old Feb 6, 2004 | 07:32 AM
seadoo's Avatar
Default Dyno Tune ?????
A buddy of mine has a 2000 Trans Am M6 with a Direct-Flo lid, FRA, and a Cut-Out. He went and had his car dynoed on a 248E Dyno Jet, and here is the numbers that he laid down... 334 hp 340 TQ/sae corrected 327 hp 338 TQ. all runs were w/ the cut-out open. When they went to tune it, they couldnt get anymore power from the car, the A/F was set at 13.3 from GM... so all they did was remove the 1-4 skip shift, and the Top speed limiter. My real question is... I have a 2000 Trans Am A4 w/ a Direct-Flo lid, Smooth Bellows, FRA, TB-Body bypass, and a Cut-Out. What do you think I can lay down on the dyno, and what do you think I can get from tuning. When I get the tuning done... I want to have the TM removed, and the shift timing quickened.
Thanks
