L92 with ported heads and carb prediction
Old Feb 10, 2012 | 08:57 AM
383vert's Avatar
News? I'm in for the updates... I'm doing a similar build, but will be going efi...
Old Feb 18, 2012 | 12:28 PM
Mikey 97Z M6's Avatar
Originally Posted by spanks13
Wow back from the grave! God we've had this engine a long time...
It keeps getting bumped in favor of other, more immediate, projects. Also, the budget took a big hit when my dad grenaded the powerglide in his drag car.
That said we almost have all the parts for it. March - June we don't really run much and we're hoping to have the car ready for the summer.
We decided on a cam grind. Its 239/252 on 110 .600/.600 that comp did for us. Haven't had it in the engine yet to check piston to valve clearance. There's a slim chance it may have enough clearance, but more than likely it'll be too close.
The rockers are headed out to CHE to be bushed.
UPS dropped off the Vic Jr. single plane intake a couple days ago.
When the rockers are back and we get the ARP hardware it'll be ready to go together!
I have a 370 with DIY ported L92's cut .030, flat top pistons w/valve reliefs, that put down 490/437 with a stock L76 plastic intake and NW90. That was with 1-3/4 headers, 9", full slicks with a 242/250 .611/.619 cam. Currently converting to a Vic and 4150 style TB. I may end up changing the cam to match up better to the Vic.
I'd say you should easily surpass 600fwhp, but cam selection will be the key factor. Everything else should easily support your effort.
Mike
Old Feb 18, 2012 | 06:14 PM
spanks13's Avatar
Awesome! Thanks for the info Mike.
What cam would you consider changing to? We picked something a little smaller on the intake to try and clear the piston without cutting it. I think a 248/260 with low 600 lift on 110 or 108 would run like crazy.
All the ARP hardware is in the mail and when it gets here we can check piston to valve clearance.
Old Oct 24, 2014 | 12:40 PM
spanks13's Avatar
Wow! I forgot about this thread. I just found it in my bookmarks from 2 years ago.
We've had the car running since February last year. It is a blast!
Have run a best of 10.30@129.25 at Fontana with no mufflers. Race weight is 3200 pounds with driver. It'd run 10.teens or maybe 10.0x at Bakersfield or Sonoma in perfect conditions.
Dyno'd it not long ago on a chassis dyno. It made 528whp through the mufflers and a powerglide with a 5200stall converter. Peak power was about 7200rpm through a 750 Holley carb. Best power was 28 degrees of timing.
Running 91 octane fuel.
Stock bottom end L92 w/ ARP main studs and rod bolts
Edelbrock Vic Jr. w/ Holley 750 - port matched to the heads
MSD 6-LS computer
L92 heads with Lingenfelter CNC ported. About 10.4:1 compression
Comp 239/252 custom on 110 low 600's lift
Hedman 1 3/4 to 1 7/8 step headers into dual 3" mufflers
Old Oct 24, 2014 | 01:38 PM
speedtigger's Avatar
Old School Heavy
4 degrees of advance?
Old Oct 24, 2014 | 02:38 PM
spanks13's Avatar
It was nominally ground on 110. It measured at low 109. Maybe 109.3
It's installed at 108.
Old Oct 24, 2014 | 02:46 PM
Old School Heavy
How high are you spinning it?
Old Oct 24, 2014 | 02:53 PM
spanks13's Avatar
At 129.5 it hit the 7400rpm chip.
I shift at about 7 and most of the time I go through the lights at 71 or 72.
Walking that fine line between trying to run it where it's happy and keeping the rods in it.
Old Oct 24, 2014 | 04:03 PM
spanks13's Avatar
Below 6500 is goofy because of the converter. I can't figure out how to get it to display torque.
The power dipped because it hit the chip at 7400. Would love to be able to run it out and see how far it carries the power.
Old Oct 24, 2014 | 09:31 PM
Old School Heavy
Wow. 7400 Peak HP. Looking at the valve events on that cam, I am surprised they did not suggest your run it on 106 ICL. Not that the 2 degrees will make much difference, but considering where you are shifting, moving the power lower in the Rs might be helpful.
Old Oct 24, 2014 | 10:01 PM
1989GTA's Avatar
To display torque, where it says none on the right hand side click on it. A pop up menu should come up. Pick torque. I have the exact same headers on my car with an L92.
Old Oct 24, 2014 | 10:52 PM
  #32
spanks13's Avatar
Thanks for the tip! Missed that completely.
It would probably run marginally better with the ICL ground at 106 vs 108. Like you said it would be a very slight change. I think this combo just likes to rev. It's in more than just the cam. Looks like it's ready to go for another 500 rpm lol.
Planning on doing a 4.125 bore build next with some ported ls7 heads. A friend of ours is going to a forged rotating assembly and mast heads on his twin turbo ls7 car so we're going to steal the parts for (hopefully) cheap. Haven't decided if it'll be a mechanical roller or hydraulic. Probably build a 388 or something similar as the car can't handle much more torque on the 9" tire. Either way it's going to want to run to 8 grand.
The headers are nice! Not bad for an out of the box swap header.
Old Oct 25, 2014 | 06:41 AM
  #33
Old School Heavy
No doubt. 350+ CFM heads on 6 liters FTW! LOL I love LS engines.
Old Oct 25, 2014 | 10:43 AM
  #34
3pedals's Avatar
the only thing holding squareport 6.0's back from reving REALLY big is valvetrain control. beyond about 7400-7500, you need carefull prep, and component selection, even that will only buy you a couple hundred more. And I know about that first hand.
Go solid roller, and there is rpms to be had....
