already posted in text, but here is the DYNO
It looks like your dyno was locked 'verter or not?
That will give you what you will see on a launch.
Then if you can lock the verter and run it again.
Locked = more hp, less torque
unlocked = less hp, more torque
Most likely you will spend most of the time going down the 1/4 mile unlocked since at wot it usually unlocks unless someone has reprogrammed your car to shift locked up top. Which might be harsh on the trans?
