VRX4 w/ 243s
Old Jan 12, 2011 | 12:58 PM
2QUIK4U's Avatar
I would say the numbers are slightly low. My Z28 had the VRX3 cam and made almost the same power with stock heads and stock LS6 intake. I would think you should be around 420rwhp. It could be in the tune. Do you have a copy of the dyno graph? However, dyno numbers arent everything. Get it to the track in the spring and see what it runs.
Old Jan 12, 2011 | 01:09 PM
Red99TA's Avatar
Originally Posted by ParkerSS
No work to them what so ever. Came off an LS2 w/ 80 miles then straight onto my car. All gaskets and bolts came from the GM kit from texas speed. I don't know anything about compression all I know is what VENGEANCE RACINGS TECHS told me! Including Mike the tuner! I'm not trying to get mad or anything but if it didnt lower it and in fact raised it then I'm not the one who gave the false statement they were.
Still wondering what could have caused the lower numbers, weither it be in my set up or in the tune. Any ideas?
I understand - gotta learn sometime. Compression basically depends on the volume between the top of the piston and the bottom of the combustion chamber. So if you increase the volume by running a thicker head gasket, cutting valve reliefs into the top of your piston, running an aftermarket piston with valve reliefs already in it, or removing some material from the combustion chamber during porting, etc. then you'll have lower compression. I would ask the Vengeance guys again what they meant as it doesn't sound like they changed anything to result in lower compression.
As for your power 400RWHP from a stalled auto isn't horrible - it might be 5-15HP less than expected but as mentioned take it to the track to see what it traps. Trap speed plus the weather conditions and your race weight will help determine what it's really making.
Old Jan 12, 2011 | 01:21 PM
ParkerSS's Avatar
I do. I'll post it up as soon as I can. We just had a snow storm hit so power has been out and I'm doing this via my iPhone. Atlanta and we still have like 6in of snow..rediculous lol
But thanks for all the input guys! I'll check on this compression thing and post up my graph as soon as I can. I'll also look in to the tune a little bit.
Old Jan 12, 2011 | 11:08 PM
desertLS1's Avatar
I made 415rwhp same set up, bigger stall, with a badly slipping tranny.
Old Jan 12, 2011 | 11:58 PM
ParkerSS's Avatar
I've been having tranny issues as well but not on the dyno.
Who did your tune if you don't mind me asking?
Old Jan 13, 2011 | 02:56 AM
01ssreda4's Avatar
It seems down a little on power, not much. The autos just dont dyno well. A trip down the track and a look at mph would be a good indication of the dyno indicating slightly low or not. I am running a very similar setup and would hope to crest 400 although not by a ton. My car feels strong though and thats whats important. Coming from a TR224/241 heads to a Cam Motion 228/232 with 799 heads I feel like I picked up 40 hp. And thats what really matters
And +100 on compression going up. You went from a 67cc chamber to about a 63 (I think). Not gonna make a ton of difference on the dyno though.
Old Jan 13, 2011 | 09:56 AM
firefighter813x's Avatar
Originally Posted by blocc monster
Those heads made yours compression higher like 10.5. from 10.1 by the way.
yup.... your power is kind of low. I have a factory LS6 and I would be really bummed to have a cam of that size combined with a Fast making 400. My older stalled LS1 auto with the MTI X1 made 377,387,395 on three different dyno's with a Vig 3600 and 806 heads. The highest dyno was with the LS6 intake too...
Old Jan 13, 2011 | 11:47 AM
ParkerSS's Avatar
Thanks for all the input guys!
So what could be causing my low numbers? Tune possibly?
Old Jan 13, 2011 | 02:40 PM
HoLLo's Avatar
My guess is tune, or other problems with the motor
Old Jan 13, 2011 | 05:21 PM
ParkerSS's Avatar
Such as? I have no abnormal noises and it isn't driving odd at all and has never threw a light other than when I did a mod that would set one.
Old Jan 14, 2011 | 12:08 AM
01ssreda4's Avatar
It could simply be a lower reading dyno. All dynos do not read the same, even with the correction factor.
Old Jan 15, 2011 | 05:27 AM
  #32
kdavis's Avatar
How is the valvetrain noise? I put a cam similar to that one in my trans am and it is pretty loud.
Old Jan 15, 2011 | 09:14 AM
  #33
PREDATOR-Z's Avatar
more bench racing please.
That is good power for the size cam and overlap at hand.
Old Jan 15, 2011 | 09:58 AM
  #34
ParkerSS's Avatar
It's not that bad IMO anyways
Old Jan 15, 2011 | 01:36 PM
  #35
Omega Doom's Avatar
my car made 414rwhp/390rwtq at RPM in lewisville tx this was with just a RPM 5 cam long tube headers,true duals, TSP lid,Yank 4200 stall and Sam88gta1 tuned it's a stock block,intake, tb,241 heads,and no pulley or ewp and thru a stock 3.23 rear! so i would think your heads would have made the numbers a bit more?
