Need Help determining a problem... car falls on its face at 6000 rpm
Old Feb 15, 2011 | 12:33 PM
soundengineer's Avatar
Default Need Help determining a problem... car falls on its face at 6000 rpm
basics.
forged 408 11.2:1 compression
PRC 227 Race Heads
Futral custom cam 248/256 .649/.646 112+4
Manley Double Springs good to .700
Spring pressures are 446/170 respectively
7.500 Pushrods
comp Lifters
Lifter preload measures out at 5/8 a turn or roughly .030 preload
Kooks 1-7/8 Longtubes
FAST 90/90
removing the Lid makes no difference in power(so the lid is not causing a restriction)
car makes great power up to 6k, and then just falls on its face
Attached Thumbnails Need Help determining a problem... car falls on its face at 6000 rpm-02-14-2011.jpg
Old Feb 15, 2011 | 12:37 PM
SSmoked1's Avatar
In a 408 with that large of a cam shouldn't you be in the 500hp mark even before it dies at 6k?
Old Feb 15, 2011 | 12:44 PM
this dyno is stingey as a *****...
450 hp on this dyno is a mid 10 sec car with a good 60' and some traction in an F-body
we think the car will do 460~470 on this dyno if we can figure out why its not pulling to 7K like it should
Old Feb 15, 2011 | 02:07 PM
Ragtop 99's Avatar
Assume you logged the usual suspects (e.g. fuel pressure, misfires, MAP) with no help?
Old Feb 15, 2011 | 02:26 PM
oh yes... 100% sure its not any of the usual suspects...
fuel is fine, spark is fine, all sensors are fine
Just got off the phone with texas speed... they think the cam may be degree'd wrong.
so I may be cracking into the engine next week and breaking out a degree wheel to see if it got installed correct or not.
Old Feb 15, 2011 | 04:02 PM
YellowToy/A's Avatar
I have to ask. Did you check to make sure the TB is opening all the way at 100 pedal?
Old Feb 15, 2011 | 05:37 PM
yes... covered under making sure all sensors are working correctly...
but thanks for asking...
Old Feb 15, 2011 | 05:45 PM
WKMCD's Avatar
What do you have behind the LT's?
Old Feb 15, 2011 | 05:55 PM
3" Y-Pipe with no cats, and 3 " Magnaflow exhaust
even if this was the problem... I dont think it would fall off that hard or that early.
I'm starting to wonder if the cam got put in wrong because the HP/TQ peak is so low for this big of a cam.
but its on the list to check...easy enough to just pull off the pipes on the dyno to see what its going to do.
I know it will help power.. I doubt it will shift the entire curve over 800 rpm
Old Feb 15, 2011 | 06:01 PM
the more I stare at it, the more and more I think its off a tooth or something...
torque should peak closer to 5200 ish on this cam...
which would fix the top end as well...
Old Feb 15, 2011 | 06:50 PM
ctd's Avatar
ctd
I just had a quick look at my 416 runs, smaller cam, torque peaks around 5100 & hp @ 6250.
No strange looking valley between the two peaks either.
Thinking a bit more, this cannot be your car? No way you would not have degreed the cam...right?
Old Feb 15, 2011 | 06:54 PM
Kaltech Tuning's Avatar
Which comp lifters?
7.500 sounds like a lot of pushrod for that setup, especially for only .030 preload. I'd say forget the BS rocker bolt turn method to figure preload and get a pushrod length checker to actually measure properly.
Old Feb 15, 2011 | 07:59 PM
1989GTA's Avatar
Dyno Dynamics dynos are usually stingy on their horsepower ratings. You would need to take it to the track to find out for sure.
Old Feb 16, 2011 | 12:17 AM
Carma Performance's Avatar
The reason for the swing in the torque curve is the dyno figuring out how much it has to fight the car to create its desired ramp rate. It pours on the load for a second then lets it off then the "sweep" settles in and you get your actual power curve. So the first couple hundred rpms of any pulls on our dyno arent the engine's power curve.... its just showing what the engine's putting to the wheels at that moment with varying amounts of load. It just takes it a second for it to get the amount of load right.
Old Feb 16, 2011 | 12:22 AM
Originally Posted by Kaltech Tuning
Which comp lifters?
I'm pretty sure pushrod length is not the issue...
Heads have a .100 thicker deck than stock heads.
pushrod length confirmed by texas speed... who builds tons of these motors, with these heads and stock rockers...
7.5 is correct length...
preload is around .030 which confirms the pushrods are the right length.
Old Feb 16, 2011 | 12:24 AM
and I also confirmed today that the cam should peak around 5200 on the torque and around 6500 on the horsepower....
its obviously about 700~800 rpm low...
would the cam being off a tooth on the timing chain shift it that far over?
or would it just run like total dog **** if it was a tooth off..
Old Feb 16, 2011 | 01:37 AM
ctd's Avatar
ctd
Are we talking about the same thing?
Between the peaks I'm referring to peak torque & peak HP not the initial part of the sweep.
I've only visited a DD dyno once with my passed 346 & found the shape of the curves very similar to the Mustang's that I'm more familiar with.
If the torque was peaking at the higher rpm where it should be when the two curves cross the dip would not be there.
Old Feb 16, 2011 | 01:47 AM
you guys arent talking about the same thing
as far as two humps...yes they are always there.. it would.. you just would not notice them as much if it was shifted higher up
torque still eventually has to go down...
and it wouldnt fall off this hard this early normally...
Old Feb 16, 2011 | 01:57 AM
I figured out that a tooth on the big sprocket is 8.1818181818* on the Manley Double timing set. (360*/44 teeth)
in this engine... an addition 8* would not cause Piston to Valve Clearance issues....
engine has -10 cc pistons...so theres still probably close to .200 clearance
I can only guess at this being the cause of the problem right now as that would shift the peaks both considerably lower and it would suddenly drop off like it does up past 6k rpm's...
I'll pull apart the front side of the engine next week when I get back into town...
Old Feb 16, 2011 | 10:14 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Even if it's not off a tooth, without checking it with a degree wheel, you cannot be sure that the timing set isn't off...we've seen cams installed dot-to-dot properly off by 7º from their intended ICL (little because of the cam and rest because of the timing set)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
