AFR225's
Old Mar 21, 2011 | 06:21 PM
Transam1's Avatar
Default AFR225's
What kind of results should i expect with a set of AFR225's on top of my 383 ls1? They are milled to 59cc and my compression will be about 12to1. I do not have cam specs but it will be aggressive (as big as i can go that Pat G will suggest). I just read that a guy with PRC 2.5 heads got some good numbers on a mustang dyno. I have an A4 with 3600 stall and 10 bolt at the moment.
Old Mar 21, 2011 | 08:43 PM
darooke's Avatar
Do you have headers or a y pipe? other supporting mods? If so i could see 450+whp and 410+tq with the right cam
Old Mar 21, 2011 | 10:54 PM
Transam1's Avatar
yes, all supporting mods, sorry forgot to add that stuff, going to have duel cutouts are the headers instead of at the Y where i have it now. how are people getting 480+ i wonder?
Old Mar 22, 2011 | 02:51 PM
mike c.'s Avatar
I made 463hp 414tq with afr 205 heads on a 346ci ls1,m6 car. Also,i was on a mustang dyno that i lost 25hp on when i went to it from a dynojet. You with the RIGHT set up should get 450hp to 460-ish-hp. Match your intake,cam and heads and you will have a fast car.
Old Mar 22, 2011 | 11:16 PM
SS1875's Avatar
I made 470 hp/ 440 TQ , with old LPE 243's heads, FAST 90 unported, 23x/24x cam. Tune was suspect though as far as timing.
You should be somewhere in the 450-480 range easy.
Old Mar 23, 2011 | 03:49 PM
Bludevil415's Avatar
You should send the heads to Tony and let him work his magic on them. Take a look at my sig. I made 484/412 threw cats with a 346 and afr 205's and supporting bolt on's.
