What to expect with a 5.3 and N20?
Old Mar 28, 2011 | 04:51 PM
89ROC-Z's Avatar
Default What to expect with a 5.3 and N20?
Want to keep working on my car but tuition keeps rising...forcing me to cut back on a few things. have a 5.0 with a complete nitrous setup and the lil guy took 100 shots just fine but the clutch didn't.
What kind of numbers could i expect with a cam only 5.3, ls1 intake, and a 6 speed? i would spray a 100 at least, going to 150. This car is pretty much just a weekend cruiser.
Thanks
Old Mar 28, 2011 | 05:02 PM
65panel5.3's Avatar
i would think right in the nieghbourhood of 550 at the motor. assuming all the tuning is good and you have a well matched cam to the application. that would be my best guess.
Old Mar 28, 2011 | 08:33 PM
89ROC-Z's Avatar
that sounds extremely high even with a ~150 n2o
Old Mar 30, 2011 | 06:52 PM
65panel5.3's Avatar
a 5.3 stock makes around 345 at the flywheel with no accesories being driven, add a decent cam and you should be able to pick up a good 40-50 horsepower if matched correctly, theres 400 right there. the ls1 intake will gain you roughly 10-12, plus the 150 shot, id say its a good ballpark.
Old Apr 5, 2011 | 07:09 PM
fuzzyjk's Avatar
Assuming a dry system.
Motor 290-310
Cam 45-55
Nitrous 100
465hp at the crank, 410hp at the wheels
BTW..... the LS1 intake will rob some TQ from what the truck intake makes.
Old Apr 14, 2011 | 03:51 PM
IH8FORD's Avatar
If it helps my 4.8 in my 07 silverado ran a 12.64 with a cam and headers on a 150 shot. The race weight was over 5000 lbs. So I'd say the 5.3 would push over 500 at the flywheel on nitrous.
Old Apr 15, 2011 | 10:58 AM
kinglt-1's Avatar
450whp with those mods and a 150shot
Old Dec 14, 2011 | 11:08 AM
L$X$10's Avatar
my 5.3 put down 330/390 on a dry 50 shot...this was before i had longtubes and a cam...ill be shooting for 500 to the wheels with a wet 150 shot...this is through 3.90s and 3600 converter
