Just got back from the dyno
Old Mar 30, 2011 | 08:03 PM
splitfinger09's Avatar
Default Just got back from the dyno
Setup
TrickFlow As Cast 220cc Cylinder Heads- 3.90 Bore
Fully Assembled Including .650 Lift Springs
Mill to Desired Compression-61cc
Hardened Pushrods
228/230 .588/.592 112 LSA Camshaft
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Front Cover Gasket
Front Cover Seal
Waterpump Gaskets
GM Crank Bolt
Powerbond 25% Underdrive Pulley with Gates Belts/GM Bolt- F Body
Comp Drop In Hi Performance Lifters
Katech C5R Timing Chain
Melling Hi Volume Oil Pump for LS Engines
SVO 42lb/hr Fuel Injectors
GM MLS Exhaust Manifold Gaskets
Poly Motor Mounts
Kooks 1 3/4 LT's
LS6 Intake
TSP 3'' True Dual Exhaust
426 HP 413 TQ
What you think?
Old Mar 30, 2011 | 08:05 PM
msydow's Avatar
what trans and gears do you have?
Old Mar 30, 2011 | 08:07 PM
m6 3.42
Old Mar 30, 2011 | 08:13 PM
msydow's Avatar
seems kinda low. i made 420/395. with an MS4 fast92/PTM 92 and stock 853 heads. prob just the dyno though. many people dont know that chassis and engine dynos are actually used for disappointing people that just pent a bunch of money on their cars. numbers dont matter. how does it feel? got any vids?
Old Mar 30, 2011 | 08:27 PM
Yeah I was hoping for 450hp as it seemed so many people were getting that no prob with that setup. I am pretty happy with the torque though. It pulls very very hard. traction is def an issue. Im happy with it so I guess thats all that really matters.
Old Mar 30, 2011 | 08:34 PM
msydow's Avatar
long as you're happy. you do the install?
Old Mar 30, 2011 | 08:35 PM
of course def was a rewarding project. I was just happy it ran let alone put down the numbers it did.
Old Mar 30, 2011 | 08:41 PM
msydow's Avatar
ha ha that was good for a laugh.
i do all my own stunts errr uh work too
just ordered my buddies TSP tsunami
cam and other misc crap to put new lifters
in it.
post up a vid of the traction issues... maybe we can
help diagnose that problem....
Old Mar 30, 2011 | 09:23 PM
i do all my own stunts errr uh work toojust ordered my buddies TSP tsunami
in it.
lol yeah thats how feel too. As far as traction goes im thinking its just my stock suspension with that amount of power is not gonna cut it. I have nitto DR but they have about 12k miles on them so im sure there about done. Next mods are full suspension inc a 9 inch and a new clutch.
Old Mar 30, 2011 | 10:00 PM
itsslow98's Avatar
do a FAST intake and i think youll see some great gains.
Old Mar 31, 2011 | 08:01 AM
Slowhawk's Avatar
LS1Tech Sponsor
Thats a really nice curve. Screw the peak #'s. It makes 400+hp from 5200-6700rpm.
Old Mar 31, 2011 | 09:37 PM
Mazzenger's Avatar
Looks good!
Old Apr 1, 2011 | 07:07 AM
hellbents10's Avatar
LS1Tech Sponsor
I agree with Slowhawk, looks like a great curve! Should run really well at the track.
Old Apr 8, 2011 | 07:34 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
if the red line on the air/fuel graph indicates 13.1 AF, then is looks real lean, especially up top
Old Apr 8, 2011 | 07:57 PM
bayer-z28's Avatar
Prolly the LS6 intake holding back a couple horses.
Old Apr 8, 2011 | 08:49 PM
1989GTA's Avatar
"if the red line on the air/fuel graph indicates 13.1 AF, then is looks real lean, especially up top"
Exactly what I was thinking.
Old Jan 1, 2012 | 11:13 AM
So what should I tell my tuner? The car is running pretty rough. By rough I mean it back fires at high rpms and the car feels like it shutters real bad. Also when pulling out in first gear the car feels like it lugs really bad then kind of comes alive at about 2500 rpms...
Old Jan 1, 2012 | 11:47 AM
BrntWS6's Avatar
Just curious, do you have an aftermarket fuel pump? If not do you feel you have the need for one? I've got H/C/I and wondering if I should install one.
Old Jan 1, 2012 | 01:51 PM
No I do not. Im not really sure if I need one or not. Never really thought about it actually.
Old Jan 2, 2012 | 01:20 PM
ls1 1990 VN's Avatar
I'm not up with what an F/Body fuel pump flows but with the power you're now making it will be a wise choice to upgrade.
