just did a dyno on my 00
Old May 1, 2011 | 01:05 PM
trans665's Avatar
Default just did a dyno on my 00
i just got this car about three months ago, every thing is stock except a mild cam,headers,injectors,tune,and suspension,which came in the car.
my numbers where 364.2 hp to the rear wheels, what would my hp at the flywheel be?
im thinking about buyiny a procharger system..... my numbers would be around 600 hp with a good tune...am i right,or thinking to povitive
they told me the364.2 hp was good hp on my car...any openions?
i cant wait to see what i can push out of this engine.
Old May 4, 2011 | 05:20 PM
rob69zombie's Avatar
My 2000 SS dyno'd 10rwhp less than yours and I just have an LS6 intake and lt's. Unless you were on a Mustang dyno, I'd guess it was a little low.
Old May 4, 2011 | 05:21 PM
Also, I'm a 6 speed; what are you? Auto cars dyno lower.
Old May 11, 2011 | 11:30 AM
mhorn0817's Avatar
i was gonna say that seems slightly lower, ive seen intake,exhasut,intake manifold and TB ls1's fbody put down around 350rwhp
Old May 15, 2011 | 01:04 PM
Layzie650's Avatar
Those dyno results are good already, but you can always go for more hp, should try putting up a dyno vid up
Old May 17, 2011 | 06:33 PM
V68Sweep's Avatar
With that much hp to the wheels, you're making approximately 418.83 at the crank. There is about a 15% loss of power from the crank to the wheels, so on newer cars just add 15% to your wheel hp and that's probably a close number to what you're at in the crank. Much older muscle cars can loose between 20-25% by the time power is transferred to the wheel!
