FAST 102 on stock cubes?
Old May 30, 2011 | 04:21 PM
lemons12's Avatar
Originally Posted by chrs1313
I am still lost how we got on the spray...the original post said nothing about nitrous...
check out what tick just ram with a non optomial setup cam only with a glide 6.05 in the 1/8th
obviously a 347 is going to be more reliable but you pay for that plus I would take a good *** tuner/ nitrous on a 346 over Joe nitrous junky on a 347 anyday of the week...I have seen plently of holes in 347s and only on a 200 shot...
I know the op sprays his car from another thread we are in.
It is crazy what tick ran, highly impressed me. I almost thought I read it wrong. Haha
No doubt... But all else equal a 347 is always superior In that scenario.
Old May 30, 2011 | 10:51 PM
IWGF's Avatar
Originally Posted by 98blueSScamaro
i dont get any of you guys. Even if he did a stroker he would need a upgraded intake to get the moneys worth out of the stroker
No plans to stroke at the moment... Later on down the line, I'd like to do a 408.
Originally Posted by lemons12
If you buy new, with a few upgrades, it Is around 1700-1800 shipped for a rotating assembly.. almost exactly the price of a new fast setup. That Is with a new crank balanced and all.
You could most certainly piece together a new assembly for under 1500.
Add 800ish or so for machining.
So for an extra 700-1200$, depending on what you want and how you buy it, you have a forged 347.
My tune runs 200$ no matter what... And I would pull and install the motor myself.
I'm not arguing.. I put my idea and what I wish I would have done out there. It's not what you want and its not a big deal.
Not a 347..
See above. Later on, I want to do a big motor, but for now, I'm looking into a FAST.
how much hp does a 347 make over a 346?
Not anything worth mentioning.
Originally Posted by breze84
Probably around 25whp...... What kind of power are you currently making with the LS6 intake????
Currently, w/ the cutout closed, through a steel D/S, 28" slicks, and a 9", 405rwhp/400rwtq.
Um very close to the same and the reliable hp is in the setup and tune. ask noz thats why he went 9.30's with a stock 346 and ls6 headed motor on a 200 shot and that was on a safe tune. and once again what ggod is a bigger motor if you dont have the lungs meaning heads and intake setup to support it.
It's very doable to go fast on a stock bottom end.
I'm not suggesting a 383 build, I'm suggesting a 347.
I would much rather spray a 250 hit on a forged 347 than a stock 346, as would anybody. Especially since this Is his DD.
I'm fully aware of what stock block ls1s are doing on the jug. Tick just posted his stock short times up on a 250hit with a cam only motor, it could easily hit 5s@almost 120. However, a 347 would last a Hell of a lot longer than a 346 on any setup with a decent power adder, given same tune etc... It is forged.
Also we are talking sub 3k# cars as well, not street cars.
Roll your eyes all you want. It was my opinion. I think going to a fast 102 isn't the best next best mod for him and you don't think a rotating assembly is... So be it. I personally would rather want to spend am extra grand and reliably spray a 250-300 hit, the potential is way greater with that then it is with a fast 102 setup. I'm done now, you got my input.
Your input is appreciated Lemons. But, as above, my plans are already set. I see your logic though.
I used to spray the car. It no longer has a kit on it. I will be putting another one on, ONCE I get another DD.
I don't spray anymore, sold the kit. Another one will go on when I get a new DD.
Old May 31, 2011 | 09:55 AM
5w20's Avatar
https://ls1tech.com/forums/14894923-post216.html
102mm fast on stock heads/cam ls1
Old May 31, 2011 | 03:55 PM
miami993c297's Avatar
The FAST 102 > to FAST 90 > LS6 Intake ....that seems to be a fact.
But I heard that the 90mm TB was enough to produce some high power, any feed back on a FAST 102 equipped with a 90mm TB?
Christian
Old May 31, 2011 | 04:04 PM
lemons12's Avatar
IWGF... I understand that man, was just having a little side debate with Chrs and Blue is all.
Old Jun 1, 2011 | 12:06 AM
IWGF's Avatar
Wow. Good results for a stock heads/cam car.
Thanks.
Gotcha lol.
