402 dyno results
Old Aug 5, 2011 | 06:47 AM
camarorat's Avatar
KC, im working off my cell phone so ihave to keep flipping back to see the posts. The car has a FT ram air with their larg air box. I want to say it has the 85mm maf no screen. K&N filter. Im thinking im getting the air in maybe its not getting out? The cam is a custom grind specific to this set up. Person that specked the cam said it wasn't considered a big cam for this application.
Old Aug 5, 2011 | 06:52 AM
FlamingTA's Avatar
Originally Posted by camarorat
cell phone pic of dyno sheet
Looks like your setup stopped making power at @6400 or so. Then it looks like it flatlined from 6400 to 7500.
Do you know what lobes the cam is on?
Old Aug 5, 2011 | 07:15 AM
camarorat's Avatar
cam power band is 2700 to 6600 so its pretty much on the money in that regard. don't know what the lobes ar but its a hellraiser TNX HR if that helps.
Old Aug 5, 2011 | 04:43 PM
ramairws6's Avatar
Originally Posted by FlamingTA
I wouldn't think a 240/244 would be too big for a 402 with AFR225's.
??Who said it was too big!?? I said it was all wrong...
Old Aug 5, 2011 | 09:07 PM
camarorat's Avatar
Ramair, what cam would you suggest? Please don't take that the wrong way, I appreciate the responses from everyone, but two of the so called gurus on this site gave me cam specs (actually I had to pay them) for this build and they were both very similar grinds.
Old Aug 5, 2011 | 10:17 PM
ramairws6's Avatar
I've said my peace and i'm not gonna step on anyones toes......
Old Aug 5, 2011 | 10:38 PM
FlamingTA's Avatar
It was jmdgto that said it was too big. I guess I should quote the post that I commented on next time.
Old Aug 6, 2011 | 12:13 AM
Detoxx03's Avatar
That is way low especially if the converter was locked. For a 402 I would have went with a bigger cam. Something doesn't add up with the combo cause a h/c 402 should easily put down over 500rwhp auto or not.
Old Aug 6, 2011 | 01:39 AM
KC&97TA's Avatar
85mm MAF/Lid should be letting it breath, I know the stock maf on mine is chokeing it out to 9KPa up top.
Your 1-7/8 Kooks are the right header/ORY.
Do you have a different Tuner near by? ... doesn't say your State in your sig.
The cam isn't "too big"... IMHO it's too big for the heads. If you take a look through the 408 dyno thread all 13 pages of it, the one thing that jumps out at you is the heads. Guys switch from cnc 5.3 heads left over from thier LS1 to 235cc and make bigger numbers with the same cam, you see it alot. Virginia speed has a 500+ hp car with a dink/dinky 22x/22x cam... it's got some huge heads though and a tuner that's experianced.
Your dyno numbers compared to your track numbers are comparitive to mine before I adjusted suspension and IC, my track numbers were 11.teen, 11.oh's.
We maybe hung up on dyno numbers and not what the car is actually doing... the car is performing pretty dam well.
Old Aug 6, 2011 | 06:53 AM
camarorat's Avatar
I live in New Jersey, I'm going to try and talk to RPM in Delaware.
Old Aug 6, 2011 | 08:00 AM
ctd's Avatar
ctd
Why is your dyno sheet uncorrected? Which way would your results go if corrected?
Old Aug 6, 2011 | 04:00 PM
  #32
navyblueSS's Avatar
My 402 made 513/462 with ported TFS 215 heads and a FMS 246/253 cam. I highly doubt the heads are the problem.
Old Aug 6, 2011 | 07:34 PM
  #33
MikeG's Avatar
And those are STD numbers too... Wow. Lose the yella terras and the vig converter and see where that leaves ya.
Old Aug 14, 2011 | 09:13 PM
  #34
SteelCityMaro's Avatar
I agree too much cam for those heads
Old Aug 14, 2011 | 10:11 PM
  #35
sho-me speed's Avatar
Closed ex-Sponsor Account
We dynoed a car not too long ago that had a Magnaflow catback. He opened the cutout and picked up 51rwhp. You may need less backpressure for your combo.
