416 on the N20
LME built the motor with LME ported L92's
Running an unported fast 102 with a LS2 90 unported throttle body
Kooks headers/3x3 off road X out Borlas.
N20 cam 24x/25x .6xx/.6xx 113
Not sure if the shop wants all the specs out that did it. When they give me the ok, I will post them up
http://www.youtube.com/watch?v=t0GuPcTMcmM
Hi
is that on a 150 shot or 200,
a lot of Tq going on there it's very impressive......
Are you gona hit the track sometime
congrads, and good luck
Baezi
Baezi
Nice result
Can you look into your AFR curve ? I'm sure you will see a lean spike at 3400 but it recover really fast .. mostly split of second that you shouldn't care about
.. Can you look into your AFR curve ? I'm sure you will see a lean spike at 3400 but it recover really fast .. mostly split of second that you shouldn't care about
that looks more like a 250 shot motor was definetly built to run nitrouse and not N/A average numbers on a N/A are 530ish so hes way above that mark
I will only be running a 150 shot on mine since I dont have top steel rings
Thanks everyone. Really happy with it.
Set up is a LME 416. 11.5 compression. Using a standalone N20 setup with C-16 in the stand alone tank and 100 octane in the car's tank.
It is a 200 shot. Nitrous outlet 102 plate set up.
Going to the track hopefully on October 5th.
Think I answered everyone's questions.
Thanks again for the comments.
