Had the Z28 dynoed yesterday
Old Mar 28, 2004 | 08:16 AM
evil02z's Avatar
Default Had the Z28 dynoed yesterday
Took the Z to HP Racing yesterday for a couple of dyno runs. The first attempt the clutch slipped real bad so they aborted the run. They gave it about a half hour cool down and tried her again. 408RWHP @5750 and 405RWTQ @ 4750 the engien carried over 400 HP from 5000 all the way to 6300. I still need to get underdrive pulleys, a water pump, a good Y-pipe and a cut-out.
Old Mar 28, 2004 | 09:11 AM
30th t/a's Avatar
what mods do you have done to it? a4 or m6?
Old Mar 29, 2004 | 11:14 AM
evil02z's Avatar
Check the sig
Old Mar 29, 2004 | 12:48 PM
Mazzenger's Avatar
Good Number Man. Could you tell a much difference in power when you changed to the 4.8 L heads?
HP their dyno is in ground? or above?
Old Mar 29, 2004 | 01:04 PM
evil02z's Avatar
In-ground mustang dyno. The heads went on with the cam so I couldn't compare with the factory heads.
Old Mar 29, 2004 | 05:00 PM
Chris81's Avatar
Wow, those are badass #'s for a mustang dyno..
