Cut out comparision
Did I just call you old? :-)
It made 511 with them, 519 with out. It went 11.0@129 thru Cats. The 478 was thru cats cut outs closed, 511 was cutouts open thru cats. The 512 was thru the full Magnaflo no cats. All pulls 1 day apart same dyno and tuner.
As for the guy picking up over a Flowmaster, the are known to be terrible cat backs.
I have some real special ones on the car now. Hoping to see over 600 rwhp with cats and passing Canadian emissions. We will see how that goes in a week or two. They are OBDII certified too. Not cheap though.
3 1/2" inlet, 4 1/2" OD.
btw, it's a manual cutout, I only use it at the track and I just take the cover off when I put my ET Streets on. I probably wouldn't have bothered with a cutout if I had a good high flow catback but it was easier to spend $32.99 on the cutout vs $400 on a magnaflow kit with tips I dont like. Plus it just sounds cool!!!
from what it looks like... its more of a tuning issue... and the bigger the power(bigger CI or FI or N02), the more benefitial the cutouts are...
is anyone else picking up on this pattern?
The 478 was purely turbulence from the cut outs. All the power came back when we opened them. No extra power though. Not sure where people are getting lost on this.
I see people with crappy Y pipes and cat back (especially restrictive mufflers, like a Flowmaster) are picking up more power and have little more than stock bolt on motors.
That said, I do think you can gain 10ish rwhp, I just prefer to always have it all on tap all the time. Maybe that is just me.
lol i get slammed for not searching and then i get slammed for searching... i just cant win! haha
Dual 3" open cutouts after the headers - 414 RWHP
Decent y pipe and a 3" dynomax ultraflow - 400 RWHP
torque curve beefed up, but that dynomax muffler was a good piece!
I also had a single 3" cutout setup with a magnaflow out back, different dyno, that was 410 RWHP single cutout open, 390 RWHP cutout closed through the muffler. No clue what my true duals made after that.
I think a dual exhaust or even a single 3.5 using a dynomax ultraflow or hooker maxflow would be the perfect system.
Back when I had 2.25" exhaust over the axle the cutouts were worth 2 tenths and 1.5-2mph in the 1/8th mile.
Once I had 3" exhaust from cutouts to mufflers with 2.25" tails they still gained a tenth and 1 mph.
Once I had 3" from cutouts to mufflers (except a shitty joint right at the collector which was still 2.25" and entered the 3" pipe at a 45* angle) with 3" dumps after the muffler they gained little to nothing.
Since then I have corrected the joint in front of the cutouts. My exhaust guy couldn't make a tight 3" bend so I was stuck handicapping it with a 3" to 2.25" reducer welded at an angle into some 3" pipe at the collectors. This meant the exhaust left the header into an extreme bend necked down to 2.25" for a length of 2" then into 3" to a cutout to 3".
I'm curious to go back and see if I gained anything losing the 2.25" and if the cutout might start helping again since now the mufflers are a bigger restriction than the shitty joint at the collector. I know for a fact it drives a lot different in the low-mid range with a proper 3" setup all the way back.
It seems like anything with big power needs a good air intake and a good exhaust out take.. And what with dual 3" cutouts after the headers, you cant get much better flow than that haha.
But troy said a few posts above.. I looks like it does depend on the setup.
Cutouts may be overkill right now, but for future expansion, it looks like they would benefit me.
