all bore dyno results?
Old Apr 7, 2004 | 09:11 PM
Slow Z28's Avatar
Default all bore dyno results?
what head/cam combo's are being run and what have you been dynoing? Also is that M6 or A4 and through what rear end? Basically just looking at what "advantages" were had on the dyno run. Thanks
Chris
Old Apr 7, 2004 | 09:22 PM
ezss's Avatar
mine are posted on www.erikz.org if you go to the dyno link. The top two are all-bore with different h/c combos (described with each dyno). The latest is stage 2 heads and a 242/242 lunati 595 112 cam. You can also see one compared to my old h/c setup, and see the huge difference in low end torque and area under the curve.
Old Apr 8, 2004 | 09:55 PM
Slow Z28's Avatar
thanks man. anyone else?
Old Apr 8, 2004 | 10:13 PM
Linear Velocity's Avatar
I had AAP/Race Prep Stage III 5.7 heads, Cam Motion 230/236 .595/.598 114 LSA cam. Car was an M6 with a 12 bolt rear end with 4.33's. Dyno was done with full belts and 17x11's in the rear.
