2006 C6 A&A V3/Kooks/Corsa
We ended up having to do some fabrication work to make the 3" Corsa C6 Z06 exhaust fit since it was intended for a manual transmission vehicle and this particular C6 is an automatic. If anyone is interested in what it took to make the Corsa exhaust fit I can PM you some pictures.
The car when it came in had the following modifications:
-K&N FIPK intake
-3"x2x1/2" Bassani exhaust
-Stock Manifolds
-Stock LS2 short block
-Stock heads
-Stock LS2 intake
While it was here we added the following:
-A&A Vortech V3 air to air intercooled supercharger kit
-3.8" pulley(9-10psi)
-Kooks 1x7/8"x3" stainless steel long tube headers
-Kooks 3"x3" catted x-pipe
-Corsa 3" cat-back exhaust for C6 Z06
I've over laid the baseline results for the C6 before the new modifications were installed along with the results after the modifications were installed and dyno tuned.
As you can see the car is a whole different animal! We we're very happy with the results as was our customer! We do a large amount of these A&A supercharger kits and our customers really like them and for good reason.
For a stock short-block these are very good numbers, and will show those Z06 owners whose boss!
