LS2 V.2 Polluter 440rwhp/404rwtq "Cam-Only"
Old Apr 16, 2013 | 04:11 PM
babbage1109's Avatar
I def will. I'm hoping to be in the 11s
Old Apr 16, 2013 | 10:28 PM
Ls2R1Rx7's Avatar
Such a beast
Old Apr 16, 2013 | 10:29 PM
Ls2R1Rx7's Avatar
Should be able to run mid elevens like i do with your set up
Old Apr 17, 2013 | 09:45 AM
Sales@Tick's Avatar
Les,
Hell your car is solid 10 second car if you can get some traction!
Old Feb 24, 2015 | 10:22 PM
JCS94's Avatar
Hey Martin, if upgrading injectors when doing a polluter cam, what would be the best injector rating to go with?
Old Feb 25, 2015 | 08:48 AM
Rise of the Phoenix's Avatar
36lb red tops or the 42lb green tops.
Old Feb 25, 2015 | 01:25 PM
Sales@Tick's Avatar
^^^ Yup.
Or FAST 36 lb/hr injectors as well. These are rated at 43.5psi so at 58psi they will be closer to 42 lb/hr.
We sell these for right around 300 dollars as well.
Old Feb 26, 2015 | 09:58 AM
JCS94's Avatar
If I was planning on doing turbos down the road or add nitrous, would the FAST 46 be a good route to go to plan for the future?
Old Feb 26, 2015 | 10:27 AM
Lawhead's Avatar
Can't wait for my "Cam only" build to be done with some Martin Magic
Old Feb 26, 2015 | 10:38 AM
You'll need more injector for turbos. 60's or 80's, with 80's being the better choice. For nitrous, the 46's would be fine.
Old Feb 26, 2015 | 12:47 PM
Sales@Tick's Avatar
I'd go ahead and get a 60# injector then. That will suffice to 700rwhp and work well with N/A and nitrous for now.
Old Mar 1, 2015 | 02:33 PM
  #32
JCS94's Avatar
Thanks a lot for the information and suggestions, guys! I'll keep it in mind when I'm choosing which injectors to install.
