Low Power..need some new ideas.
-LTFT both sides ~ -%5
-LTFT at WOT 0
-AFR steady at 13.4 (reacted predictably to PE changes)
-Total timing 29.5 deg (More timing did not result in more power on dyno so we left it)
-Knock sensors disabled (poly motor mounts cause false knock)
-Peak pwr happens about 5800-5900 rpm.
-Peak tq at 5000 rpm
-Exhaust back-pressure <2psi
-TR 224 cam timing double checked and w/i 1 deg of card. Lift checked as well.
-65,000 miles
-Compression test had one piston %15 higher than the rest. the rest are within %3 of each other.
-Leak down shows all cylinders <%5 leakdown.
-New Spec stg 3 carbon clutch
-plugs look good at 0.055" gap.
-LS6 pcv mod with in-line filter=very little oil intake.
That about sums it up. Any suggestions would be appreciated. I've considered the unhappy thought of my engine just getting tired, but the leakdown results are convincing. I posted this on LS1.com as well but only got one reply. Thanks for any help.
As for mods:
TTS long tubes w/ cats & ORYP
Borla cat back
TR 224 563 114 cam, comp springs, and TR hardened push rods
LS6 intake, TR ported TB, SLP 85mm MAF, suncoast raptor hood & airbox
M6 w/ spec 3 carbon disc clutch, stock 10 bolt w/ 4.10 gears
All the BMR traction stuff
Your setup is very similar to mine and you have 20 more HP. It is a common theme so I'm trying to figure it out.
