My LS3 418 cid dyno result :(
Old Aug 6, 2013 | 02:23 AM
al3flangy's Avatar
Default My LS3 418 cid dyno result :(
My car is camaro 00'
Mods:
Fast 102 and tb 102 mm
Heads are ls3 stock
Cam comp custom !!!! No specs
Piston 4.070
Crank 4 inch
Headers 1 7/8 american rAcing with 3" y and borla exhaust with fully opend cutout
Gto trans
3.73 axle ratio
Mafless tune brcause i have problem with my MAF sensor and no one could to solve it !!!!!
485 rwhp / 463 rwtq @
I thought it can gave me 500+ rwhp !!!!
Do u think there is some thing wrong with my cam or axle ratio ? Or or or ????
Old Aug 6, 2013 | 02:28 AM
al3flangy's Avatar
485 rwhp /463 rwtq @ 95 degree
And my mod for street racing not for 1/4 mile
And its n/a
Old Aug 6, 2013 | 06:42 AM
Baconz28's Avatar
You never did mention your compression bro. It could be a bit low to take full advantage of your cubes. Also not knowing the cam specs ain't never good eithier. Could be some power left there also. I agree with you your car should be making around 520 or so to the tire easily.
Old Aug 6, 2013 | 07:03 AM
427zm's Avatar
Compression ratio and cams specs will help in knowing how much power is left. Also, you'll need to get the heads ported to maximize your setup. Don't be too discouraged, w/o a MAF, and the fact that it was as hot as it was changes a lot in the tune and dynoing.
Old Aug 6, 2013 | 07:29 AM
edcmat-l1's Avatar
Not near enough info to even make an assumption.
What kind of dyno?
How much timing?
What was the A/F?
Can you provide a data log and dyno graph with A/F plotted? Or A/F in a data log?
Compression and cam specs. Without knowing these, hard to tell what the engine SHOULD make.
Old Aug 6, 2013 | 08:23 AM
DietCoke's Avatar
I'm surprised it made that much through a y pipe and stock heads. Sounds right to me. Open the exhaust and heads, and you'll see 50-70 more horsepower.
Old Aug 6, 2013 | 09:35 AM
thompson's Avatar
Really not bad #s for a stock head car. The 418Ci only helps if you have the ability to use it. You have an LS3 with an unknown camshaft making almost 500HP. I say good job. What made you expect more?
Old Aug 6, 2013 | 12:15 PM
MikeWS6's Avatar
So your disappointed? Want to trade motors? Looks good.
Old Aug 6, 2013 | 08:20 PM
Sales@Tick's Avatar
We make these numbers with H/C stock cubic inch stock bottom end LS3's.
Our office mangers 416 with PRC CNC'd stock casting LS3's we built with every single part being used down to the camshaft and nothing done specific for the combination made 520/485 to the tires through a y-pipe.
Something is off for sure, it could be the cam, it could be the compression it could be the dyno it's on, it could be the tuner etc. etc. etc.
Not a lot of information given.
Also, if this is an automatic transmission I can see the numbers being OK. A decent 416 LS3 with a six speed behind it should be higher by at least 20rwhp IMO.
Old Aug 7, 2013 | 05:34 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I personally don't think that is too bad considering it still has stock heads on it. With the little information given I wouldn't be too upset about the result. Remember dyno results are the end all be all when it comes to how much power a car makes.
Old Aug 7, 2013 | 09:16 PM
redtan's Avatar
Without knowing the intake, cam specs, compression and it having stock heads those are not bad numbers.
A longer stroke isn't going to really give that much more top end hp, especially if you don't have the cam and headflow. But it will increase torque all over the rpm range.
So I'm not surprised of those numbers. It's basically a cammed stock heads LS3 with a bunch more torque under the curve from the longer stroke. High 400s for that seems fine.
Old Aug 7, 2013 | 10:31 PM
z28241's Avatar
Agree with what everyone else, also the specific dyno and DA and heat , drivetrain setup, such as rotational mass killers, ie;stall converter , heavy rims, big dr's...etc..have alot to do with numbers! JUST RUN IT!
Old Aug 9, 2013 | 04:22 PM
venom ws7's Avatar
What dyno? Any graph?
Without knowing the cam specs I don't think anyone can help you...
Old Aug 11, 2013 | 11:49 PM
Detoxx03's Avatar
Not enough but it looks solid.
Old Aug 29, 2013 | 12:57 PM
TM-96CE's Avatar
You're choking that motor with stock LS3 heads. Have them CNC ported, or go with a TrickFlow 235cc head and you'll pickup a ton of power.
Old Aug 29, 2013 | 12:59 PM
Colin1337's Avatar
pft, I'd be stoked if my motor made that kinda power n/a
Old Aug 29, 2013 | 01:11 PM
NW Iowa WS6's Avatar
Unported heads and your unhappy with 485? Ok
Old Aug 29, 2013 | 07:46 PM
Jimbo1367's Avatar
LOL. . More info needed. Compression., cam specs. dyno as others have said . That said, it probably more power than I'll ever have.
Old Aug 29, 2013 | 07:47 PM
Jimbo1367's Avatar
Is this the cam????????\\
al3flangy
Garage is empty, add now
Trader Rating: 0
Posts: 29Teching In
Vengeance stage VI cam result !!
Hello
I just want to know if there is someone have result with this cam(239/251 624/624 lsa114) on stock bottom LS3 or 416 ,418 cid na ??? Because someone advise me with this cam and i did research but nothing only low millage sale !!!!!!
Thnx
Old Aug 31, 2013 | 10:11 PM
al3flangy's Avatar
al3flangy
Trader Rating: 0
Posts: 29Teching In
Hello
Thnx
Its not the cam what i already have . But its a suggested cam for me so that i asking about it !
