procharged trans am
Old Aug 23, 2013 | 12:49 PM
383camaroz28's Avatar
Default procharged trans am
Went to the dyno this week after i could only get 5psi out of my bad intercooler.
5psi i was at 460.
347 9:3.1
Wiseco pistons
Eagle rods
Vrx5 cam 236/238
Milled 317 heads
Hooker 1 3/4
Magnaflow catback
60lb injectors/ aero 340 pump
D1sc 4" pulley
Fmic
Stock bracket
4l80
3200 5 disk
Moser 12 bolt 3.73
End of the day i left with 580/481 @ 12psi.
Car feels strong was hoping to get 600 n more tq but is what it is.
Maybe ill drop a lulley size an do poor man belt wrap
Old Aug 23, 2013 | 01:04 PM
Rise of the Phoenix's Avatar
I'm by no means an expert on blown setups, but the torque number doesn't seem right. I thought blower setups were heralded on having such high torque output.
Old Aug 23, 2013 | 01:20 PM
I know i figured id be at over 500tq
I think i should just go turbo
Old Aug 23, 2013 | 01:32 PM
ramairetransam's Avatar
i made 470 hp 500 tq with a p1 on a sdce setup with a 3.4 , stock heads, cam , never opened up .
Old Aug 23, 2013 | 01:38 PM
I should goto the track and see
Old Aug 23, 2013 | 02:10 PM
There is a difference of 100 rwtq between the rwhp; something is off. I've never seen that on any Procharger setup. The rwhp seems about right, but not the torque.
Old Aug 23, 2013 | 03:12 PM
i think my tuner said it was because of the dyno? i cant remember.
or could it be my 4l80 is eating up all the tq lol
Old Aug 23, 2013 | 03:49 PM
The track will tell you where you're at. Post up your ET's and trap speeds when you go.
Old Aug 23, 2013 | 04:08 PM
if it doesnt get into the 10s im selling it lol
Old Aug 24, 2013 | 11:21 AM
Old Aug 24, 2013 | 11:33 AM
CGCBandit's Avatar
Probably right where you should be imo, you're running a 4l80 and a 12bolt, she aint gonna be a dyno queen. Take it to the track and see what the mph is through the traps.
Old Aug 24, 2013 | 01:08 PM
Detoxx03's Avatar
The numbers are about right for the setup and that low of a compression ratio. The torque in centri setups is usually gapped like that in comparison to horsepower. I'd pulley down for more since its built. Meth injection (Alky Control) would help a lot.
Old Aug 24, 2013 | 02:11 PM
ajrothm's Avatar
I think the torque is about right. Usually around 90-100 ft lb spread from HP to TQ.
Example, my stock motor made 622rwhp/530rwtq with a D1sc and 10-11 psi. My current setup made 901rwhp and 820rwtq with an F1R and 22.7 psi..
That's just how centrifugals are, less torque and its high in the power band compared to a turbo setup.
Old Aug 24, 2013 | 04:37 PM
Yea im gonna goto track soon, never been.
Think my next pulley would be a 3.70 w/ poor man belt wrap
Old Oct 1, 2014 | 10:25 PM
HartAttack's Avatar
I'm reviving this post... Any updates to this setup at the track?
I got a very similar setup with a LQ4, ported 5.3's, VRX5, P1SC Procharger, Ported FAST 102/102 setup , 1 7/8 longtubes through a 6 speed, and I'm hoping at making into the 600's with that... But needless to say I'm really curious to see how your setup faired at the track and all.
Thanks. -Chris
Old Oct 3, 2014 | 10:33 AM
kinglt-1's Avatar
Depends on your drive train...I would not be concerned with dyno numbers anyway.
