Std
Old May 6, 2004 | 10:25 PM
00BadaSS's Avatar
Default Std
what is std. my dyno chart says std horsepower and std torque than it gives me an std correction. i have heard of sae just wondering if they are they same or how this affects my dyno results.
Old May 7, 2004 | 07:29 AM
foff667's Avatar
LS1TECH Sponsor
sae generally corrects for air temp and ****...usually you'll see a slight loss in hp with sae...i think mine was like 10-20hp less sae.
Old May 7, 2004 | 09:24 AM
Cokeroker's Avatar
actually sometimes SAE can be higher than STD if it is all hot and humid outside. SAE corrects current weather conditions back to a standard. IF it is cold and dry, then your horsepower rating would correct lower.... hope that makes sense
Old May 7, 2004 | 09:33 AM
foff667's Avatar
LS1TECH Sponsor
what factors does it use to correct it back to sae? baro, temp & humidity?
Old May 7, 2004 | 10:14 AM
Cokeroker's Avatar
correct
Old May 7, 2004 | 10:51 AM
1point3liter's Avatar
SAE is the standard used when comparing dyno plots.
