car dynoed last Friday.. have question
Old May 13, 2004 | 10:42 PM
Racer99Bird's Avatar
Default car dynoed last Friday.. have question
got the z28 dynoed last Friday, and with the mods in my sig, i put down 320rwhp and 330rwtq.
Was wondering if these are good numbers??? still have the stock y pipe on and the stock manifolds as well
Thanks for the input
Old May 14, 2004 | 12:25 AM
soundengineer's Avatar
only 320hp with a hotcam??? I thought they made more than that???
maybe its just the restrictive stock manifolds and y-pipe???
got a scan of the dyno graph??
and did you have it tuned...or just pull on the dyno to see #'s
Old May 14, 2004 | 12:36 AM
i would scan the dyno graph but dont' have a scanner, but i can tell you this, i was losing power starting at 5,000 rpm, it dropped off there... they said was losin power from the coil packs or something???? and just had it dynoed, not tuned...
Old May 14, 2004 | 08:35 AM
KGSloan's Avatar
that cam should not start dropping off at 5000. more like 6000. what springs are you running? maybe you're getting valve float. did you get an A/F reading? your tune may also just be way off.
Old May 14, 2004 | 09:54 AM
i'm running the LS6 springs.. and as far as the tune, i only got it partially tuned, like for the idle and little things like that, haven't got it dyno tuned yet..
