Lq9 trans am build
Old Jan 5, 2015 | 09:13 PM
RedDemon_ls's Avatar
Default Lq9 trans am build
I have a lq9 with ported and polished 243's bolt on's under drive pulley and a tsp 232/238 .595/.605 3600 Yank and 3.73 what Yall think it will make on the dyno and should do on the track?
Old Jan 6, 2015 | 01:21 AM
KCS's Avatar
KCS
Moderator
400whp and run 12's.
Old Jan 6, 2015 | 04:56 AM
madmike9396's Avatar
400+ and should go 11s if you can get it to hook !
What headers and exhaust are you running ?
Old Jan 6, 2015 | 05:13 AM
HCI2000SS's Avatar
Hard to say on the dyno numbers since they vary and there are different kinds as well. What tire/wheel setup will you be running, and what is the weight of the vehicle?
Old Jan 6, 2015 | 05:36 AM
scotty2000ss's Avatar
420/388 11.88 @117.
Old Jan 6, 2015 | 11:47 AM
I'm gonna be running a 255/60-16 drag radial and I'm running 1 3/4 headers to flowmaster but I always have the cut out open ! And the car it was in before was a Trans am with drop top and ran 11.88 without a cam and now i added one
Old Jan 8, 2015 | 10:26 AM
ranmas2004's Avatar
What kind of ported 243s? Those Advanced induction heads? How much the car weigh? I have an LQ9 swapped 300zx and it has Ai 243s 229/234 .600/.600 114+2 cam, 25% UDP, aluminum Crank, headers, 3" dual exhaust 102TB and 102 ported FAST 100mm MAF...and a bunch of other crap.....curb weight is 3185lbs and it made 470whp and 433ft-lbs (SAE) on a dynojet.
