Are my numbers low?
ported polished 853 heads, 237/242 .595/.595 on a 112lsa, double roller TC, hardened pushrods7.4, ported blueprinted oil pump, flowtech LT's, asp underdrive pulley/overdrive alt pulley, 28lb injectors, TR-55's w/taylor wires, free mods, ported TB, LS6 intake, egr/air delete, LS1edit. Still need some tuning. I believe thats all my mods at this time. I'm the same guy that had the PtoV issues a couple of weeks ago that bent all my int. valves. I had the heads worked and put everything back together and clayed the #1 piston. I have alittle bit of blue smoke on start up and at idle, but nothing at WOT I read in another post that I need to seal the rocker arm bolts. So thats my 2 questions are my numbers low and how would I go about fixing the oil burning issue? Thanks for any replies.
Brandon
