418ci LS3 dyno low??
throttle cable bracket $30
Valve spring kit $300 (assuming springs not included in your 1200 dollar porting figure?)
MAP extension harness $25
Fuel Rail $100
I'm not disagreeing with you...I'm in the middle of a cathedral to LS3 topend swap right now and just making the list more complete
I assume 1500 for TEA included springs?
Fuel Rail $100
And if he buys an LS3 fuel rail for $100, he can sell his fuel rail for close to that.
Either way it would still be cheaper or close. I'm not bashing ported 243s as I have the same stuff and more than happy with it, but sometimes I think a set of rectangular style heads would've cost me less and probably made more power (at the expense of low end torque on my setup, something that should not be an issues on a 4.080 bore block like his).
A vacuum pump might help as well. But it's easy to spend someone else's money. :-p
In all reality, that was a hair bit more than what I was expecting in tq. I was initially more worried about that number over the hp. I definitely hear what your saying about the heads. I wasn't exactly expecting this. With that said, I have a problem else where that is contributing to this, even if its small. I seriously believe my cats are toast. I had a small handful of stumbles lastnite with the wife in the car around 2200 and 2400rpms. Infact, I had the same thing happen on the OLD motor cruising on he freeway one day as well. Its either the cats, or a potential coilpack. I have the delete pipes coming this week and will hit the dyno again to see. Yes you have some other areas to open up and free more power, but you're really being limited by the heads. Those are good for torque down low, as you obviously have seen, but you can't expect ridiculous amounts of power up top...it's just the nature of the beast.
prime example right here.
https://ls1tech.com/forums/dynamomet...ast-102-a.html
thats whats i was saying
. Well there are key things like mentioned....1 3/4's vs 1 7/8's, Unported FAST (will be doing sometime this summer), and (im certain) cats. Im headed back to the dyno once I get the cats off. Other than what ive listed, I really don't know. Dyno numbers are not just numbers, they are a clear representation of where the car is. How many times do guys say that and come to find out weeks later the tune was off or something else. Yes some read a bit low and some a bit more but if you aren't even in the realm of where your build should be it's a clear indication of a problem.
