Turbo ls1 Hp guesses?
Old Oct 28, 2015 | 06:55 PM
SSLogan's Avatar
Default Turbo ls1 Hp guesses?
Hey guys, I got a 2000 Camaro SS m6 pretty recently. The motor internally is 100% bone stock 32k miles. It has a Turbonetics t76 turbo, and 80# injectors. I was told it made 445rwhp on 8psi, and I thought this was a little low. Right now, it is supposed to be at 9-10psi. I was wondering if anyone is running a similar setup, and making similar power. Thanks
Old Oct 28, 2015 | 06:58 PM
HCI2000SS's Avatar
If it's truly bone stock 445 sounds about right at 8 psi
Old Nov 2, 2015 | 01:22 PM
Ls1Rx-7's Avatar
thats in the ballpark of where you should be, id go around and look for boost leaks just to be sure. if you arent running t-bolt clamps then id order some, they seal up alot better and you can always run a small amount of rtv silicone around your couplers to insure they dont leak.
if your worried about the numbers id look into a tick performance boost cam, my buddy added 80rwhp at the same boost with only a cam, trunion rockers, pushrods and springs. he was at 12psi
