Huron T6: S484 on only 14lbs
Motor:
346 alum ls1 block
Main girdle/studded
Callies Crank/Rods
Wiseco Pistons
TFS 220 as cast from Brian Tooley
Stage 3 cam LJMS
Schumann Oil pump
10:1 Static
16 degrees total timing
Fuel:
e85
Magnafuel 4303 external with Walbro 255 in tank
Magnafuel Regulator
ID 2000s
Trans:
Built TH400 w/brake
Circle D converter
Rear:
Dana S60 with 3:54s
I will add video later of the pull. Car made 852 rwhp and 712 tq on 16 degrees of timing. We only made pulls on 14lbs for now and plan on turning it up to 20 or so this spring once we get a controller on the car.
