What kind of numbers
Old Jun 18, 2004 | 09:45 PM
point of vue's Avatar
Default What kind of numbers
...should I expect with these mods? The car is a 1993 Z28 with a 396 swap. M6 tranny, stock gears (323) and no torque converter. The mods are as follows:
Dragonslayer Forged Crank
SRP 396/ 14cc dish/ 5.850" rod
5.850" H-beam Rods
Canton oil pan SBC Fbody
Blueprinted high volume oil pump
Comp R lifters
Pro Magnum Roller Rockers
Comp Cams Pushrods
58MM Arizona Speed and Marine TB
Moroso Cold Air Intake
Hooker Long tubes (JetHot Coated)
Street Twin clutch
F.A.S.T. engine management with wideband 02 sensor built in.
Comp Cams XE 236/242
Accel 300+ ignition module and coil
Pro 5.0 Shifter
36# SVO Injectors
Ported Heads
Cloyes Double Roller Timing Chain
Electric Waterpump
Vented Opti
Taylor over the top wires
255GPH fuel pump
