ls1 swapped S2000 first dyno
Old Apr 21, 2017 | 12:30 PM
lols2k's Avatar
Default ls1 swapped S2000 first dyno
I mostly lurk, but figured I would share this since I'm looking for suggestions
I've swapped an LS1 from an F-body into my s2000 with following mods.
Torquer V2 cam
243 heads
Jenvey ITB kit
10% ATI UD pulley
Exhaust is 1 5/8" block huggers from hooker into 3 inch piping that with a 3.5 y pipe at the rear axle with a 4in muffler.
Dyno pull video and dyno sheet:
Now here is the question:
How am I going to get another 60hp out of this motor? The goal from the start was 450whp. Obviously long tubes would help get a chunk of that, but I think I need some different heads.
Old Apr 21, 2017 | 09:29 PM
Jtm2085's Avatar
243's are pretty good heads even in stock form. I would send them to one of the sponsors here and have them ported, as well as swapping to a 1 7/8in LT if you have the space. That should put you where you want to be
Old Apr 22, 2017 | 08:33 AM
manzo81maro's Avatar
+1 on the 1-7/8" long tubes and porting the heads, that will gain huge...also if your 3" exhaust necks down to a single 3" y-pipe outlet, that will hurt you... I would upsize that outlet to 3.5" or 4", or go dual 3" all the way back..
Underdrive pulley will help some as well
Sweet build!
Old Apr 22, 2017 | 12:09 PM
lols2k's Avatar
Sweet build!
Yes I meant to clarify that. It's a 3.5 into a 4 inch muffler. Car has a 10% ATI UD
Old Apr 22, 2017 | 01:58 PM
Okay you should be good there...yea 1 7/8 and some good head work should get you close to 450
Old Apr 22, 2017 | 03:03 PM
FMonster's Avatar
N2O plate kit lol to hell with all that extra tear down work
Old Apr 22, 2017 | 06:41 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Wow that intake looks incredible!
It deserves MMS 220 or at least 223 Sportsmen Heads and a Cam Motion
LLSR, 1 7/8" LTs, 7500 RPM & 500 RWHP!
Old Apr 22, 2017 | 06:42 PM
Plate kit with his intake LOL!
Old Apr 23, 2017 | 10:20 AM
FMonster's Avatar
LOL obviously not with that intake! They certainly look badass but I would wager he would pick up across the board going to a Fast 92/92 combo with a plate kit for good measure!
