DYNO Comparisons Focused on Driveline Efficiency
Old Sep 29, 2017 | 05:22 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Small update, Driveline is installed, was delayed by fancy/schmancy couplers
That I had purchased 4 years ago not fitting inside the torque tube after
Installation on the driveshaft ($340.00 we'll see how their lifetime warranty
Applies to a part that NEVER fit its designed application lol) replaced with
Poly couplers from DSS ($400.00).
Expecting the 320 LPH Fuel Pump any day, good time to do it now before Engine &
Dry Sump Install in November.
I will do some Heat Cycles for the Diff and put 300-500 break in miles on
the clutch before returning to Dyno so hopefully ~3 weeks.
Old Sep 29, 2017 | 05:38 PM
Originally Posted by mOtOrHeAd MiKe
Did you seriously list your fluids at a mod? What kinda bullshit are you trying to pull here?!
I am joking of course. Parasitic losses from fluids is a very real thing - contrary to what LS1Tech will have you believe. I love Amsoil too.
LOL, I have used AMSOIL in every vehicle owned and in the Family
since 1989 so no change to measure. As a Dealer I am able to
Write Off 70-80% of what I have spent on this project which
by completion this year will be over 3X the initial purchase
($14.5K 10 years ago) So mentioning every now and then
should help justify the Write Off according to my CPA
(Also an Avid ZR1 Track Addict). Hopefully readers
will put up with this inconvenience lol.
Old Sep 29, 2017 | 07:27 PM
Yeah I have heard lotsa good things about AMSOIL! Some of the best synthetic lubes in the biz.
There another unsolicited, honest, and honestly shameless plug for ya....
Old Sep 29, 2017 | 09:59 PM
Darth_V8r's Avatar
Moderator
Lol, I read the first part of your post like wtf dude? And then saw the second half
Old Sep 30, 2017 | 08:11 AM
poorhousenext's Avatar
Originally Posted by NAVYBLUE210
My Tuner (for after the 396" Install) Matt @ GP Tuning, he does
Many of the Big LS HP Tunes in the SF Bay Area says the STP
Numbers are within 1 % of Dyno Jet STD Corrected #s.
Recent example 625 RWHP Here VS 620 RWHP on a corrected
Dyno Jet. Correction factor typically .99-1.01,
elevation is ~75' above sea level.
More concerned with the changes then absolute #s for this
Round of testing.
Like I said, it's an Ego thing, Tuners an you.
It should be no problem for him to plot your graph(s) using SAE factor or even STD. Be interesting to see the difference in numbers reading SAE correction factor on his Dyno.
I like Mustang Dyno are similar low reading Dyno VS Dynojet.
Engine in my car makes 360 SAE RWHP on a Mustang Dyno & 409 SAE RWHP on a DynoJet.
Weight to HP ratio on car is 9.97 Lbs per HP on Mustang and 8.71 Lbs per HP on a Dynojet.
Regardless of Dyno numbers, on Long Black Dyno, 11.78, 60' 1.97, MPH 119 with 300 TW street tires, 2800 stall converter, 3.55 rear gear. Can't even spin the rear tires...LOL
Old Oct 3, 2017 | 07:57 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Just placed an order for another case of ATL... love that stuff. When my RPM Level 5 4L70E died after just 5000 miles, the fluid was perfect and could probably have been reused if not for all the glitter in it.
Old Oct 6, 2017 | 11:24 AM
lt1z93's Avatar
Superflow STP corrected numbers in this case are about dead on with Dynojet SAE corrected numbers in the 600whp range with both at sea level in this case. Superflow SAE corrected numbers would be lower then Dynojet SAE numbers.
At the end of the day before and after on the same dyno is what matters.
I don't believe you will ever see 1/4 mile numbers out of this car.
Old Oct 6, 2017 | 01:27 PM
Darth_V8r's Avatar
Moderator
I've sort of played around locally. Two different dynojets 40-HP off at 500 HP. That sounds like a lot, and it is, but it's 8%. So, differences are relative. However, a nearby dyno dynamics, mustang dyno, and one of the dynojets all read within a couple percent of each other (10-hp at 500). All of the afore mentioned dynos are SAE corrected. No info on a superflow compared to them.
But assuming an honest attempt at keeping the dyno properly calibrated by the respective owners, you're not that likely for a 480HP car to be 350 on a different dyno. So, I still do take dyno numbers at face value, knowing there's a +/- 5% slop in there. Someone says their car dyno's 440, I take it as it's close to that. Could be 425, could be 450, but it's close. Typically guys who track often, their track performance will back it up.
In the end, your 1/4 mile trap speed and DA when you ran it are probably the best power metric, but even then, driver skill, wind conditions, track surface, tire selection... there are still variables so it's not perfect either.
I still think that for what the OP is proposing, as long as the yard stick is consistent, differences will be real and valid.
Old Oct 7, 2017 | 11:42 PM
Small update, I picked up my C5 Tuesday from Ditos Motors
In SSF, complete Driveline and rear suspension R & R (coilovers,bushings,
And braces, trans/diff, & trans to chassis) feels really solid & tight.
These guys are really GREAT! only place that works on my
Corvette along with Abel Chevrolet, the Two best shops in Nor Cal
for LS Performance IMO.
Ditos did 2 heat cycles for the Ring and pinion gears, one static,(wheels elevated) one dynamic. First time driving car & clutch since Hernia procedure
left side ~6 weeks ago so somewhat apprehensive. Clutch feels Awesome! I don't believe it has+10% more pedal effort than stock.
Glad I listened to Tony, recommending new OE Master & Slave cylinders,
VS Aftermarket.
Pedal engagement is very progressive and engages roughly
In middle third of travel. Needs about ~+150 RPM to engage from a
stop on flat pavement (no hills of SF LOL!) I could definitely feel less inertia
from a stop, I did NOT stall on the way home, ~ 10 miles 12 stops 1500-3000 RPM easy driving. Thursday (little sore Wednesday and decided not to push
it, 59 years old and a Personal Trainer for 34 years, decided to follow my
own advice I give to my clients, lol) I drove ~ 17 miles, got on it
a little, shift 1-2 @ 5K, 2-3 @ 5K, then@~4K in 3rd <75 MPH
(service active handling engages early, not at 80 MPH like dash warning says so fun over). Definitely feels like it spins up a little quicker in 2nd so far
anyway.
I knew replacing my active shocks with coilovers would do that till I
get to Abel Chevrolet to tune out with Tech II, on 20 Oct.
7+ years to this point I can wait a few more weeks, in the meantime I am in
So Cal for My In Law Memorial Service this Tuesday, then preplanned mini
vaca next weekend. I will do 2 more mellow heat cycles and then figure 8s for the LSD, then Abel and some Hwy Break-In miles before changing fluids
and a return to the Dyno,
Contrary to my Tuner's comment I will try to
get up to Sonoma Raceway for a few 1/4 mile passes (weather and track schedule permitting) before going back to Abel again, in mid November for the
396" Install.
Update turned out to be more then a little.
Thanks for reading.
Old Jan 11, 2018 | 12:09 AM
GrannySShifting's Avatar
So 4 months later, did you ever redyno it to see if it gained more than 5 hp doing all that stuff? And how in the hell have you had a motor for a year almost you havent put in the car?
That on STD correction definitely reads little higher than a Dynojet on SAE correction, they are prob equiv STD corrected
Old Apr 8, 2018 | 10:31 PM
Guess thats a no LOL
