Huron Speed T4 V1 turbo kit dyno This is the latest dyno for my car after going to E85 with this kit. I am wanting to either go to a T6 or twin turbo kit from them, I feel like this T4 is holding me back some. Build on car is: LME 408, LJMS cam,TEA TFS245s, LS6 intake, ID1700s, Twin Walbro 450s, Huron Speed V1 T4 Turbo kit with Borg Warner S480 turbo. http://i67.tinypic.com/vnd0g0.jpg |
How much boost and what trans is in the car? |
Originally Posted by INIT2WIN
(Post 19839630)
Pretty bad ass! What's traction like? |
Originally Posted by T.Man
(Post 19840098)
what size cam? |
Originally Posted by RealQuick
(Post 19840392)
what size cam? |
Sure looks like an exhaust back pressure issue. What is your exhaust setup from the turbo back? |
Originally Posted by FrankieD
(Post 19843793)
Seeing you have a 4 inch straight dump it is looking like the T4 housing is the issue, How about any possibility of valve float ? at 20psi are your valve springs appropriate? |
(Post 19843864)
"Assembled CNC-ported LS1 heads come equipped with 1.300" dual valve springs (for hydraulic roller camshafts up to .625" of valve lift), Viton canister-style valve seals, 7° machined steel valve locks, and 7° titanium retainers." These may be questionable. May want to look at what springs you really have |
according to Trickflow website the springs should be good to .700 https://www.trickflow.com/parts/tfs-3061t003-c74 this is getting to be confusing |
(Post 19843939)
What is kind of odd is the shop that did the work and tuning didn't say anything about it to me after they tuned it. The only thing they said was needed to upgrade my coils because anything above about 20 psi it misfires because my coils are old and not strong enough to run that much boost. They said to get some LS3 coils since they will pretty much bolt right in. |
necrocannibal, What size wheels are in that turbo....compressor and turbine..? . |
Originally Posted by LS6427
(Post 19844378)
Originally Posted by necrocannibal
(Post 19844386)
It is a billet 96mm turbine wheel and 1.25 A/R exhaust housing. It was the largest T4 I could get to be a direct fit on the kit I have. I was hoping to make over 1,000 RWHP also....... But doesn't look like it'll happen with a T4. Unless I do a little modding and use the Borg Warner ETR 85/96 with V1 race cover from Forced Inductions. JZ estimated I could make 1,300 RWHP on my 390ci. Even if that isn't possible, anything over 1,000 would be nice. Yours made some kick ass power though.....good job. . |
(Post 19844649)
I have the Huron Speed V2 A/C T4 single turbo kit. Not sure if yours is the A/C type kit. I was hoping to make over 1,000 RWHP also....... But doesn't look like it'll happen with a T4. Unless I do a little modding and use the Borg Warner ETR 85/96 with V1 race cover from Forced Inductions. JZ estimated I could make 1,300 RWHP on my 390ci. Even if that isn't possible, anything over 1,000 would be nice. . Yeah I am in the same boat as you, I wanted to get to 1000 with this set up but I don't think the T4 flange is going to get there. I am planning on pulling this kit off and just doing twin 76s or something and making sure it gets over 1000. |
Got any pics of the s480 on the V1 huron kit? I have the same kit and looking to go to a s480 from a billet 7875 |
© 2024 MH Sub I, LLC dba Internet Brands
