Ls2 swap on a V6
Old 08-18-2018, 02:00 AM
Maxwnn1234's Avatar
Default Ls2 swap on a V6
I知 doing an Ls2 swap right now and I wanted to know how much power it値l make at the wheels;
-LS2 SBE
-LS3 Intake
-LS3 heads P&P
-42lb injectors
-Stage 3 btr cam
-Btr spring kit
-New timing set
-Built 4l80e
-3600 Stall
-Carbon Fiber shaft
-Ford 9in Rear 3.23-3.73 gears (depends)
-Possibly ~100-150 shot of nitrous, down the road
My builder suggests that it値l be ~550 at the wheels just want to see what others got with the same set up.
Old 08-18-2018, 07:50 AM
HCI2000SS's Avatar
Being a stalled auto I'm thinking more like 480-500 rwhp on an honest dyno. But hard to say since dynos vary
Old 08-18-2018, 11:01 AM
Maxwnn1234's Avatar
I know this may sound dumb but would it make a difference if I locked the torque converter or if I left it loose?
Old 08-18-2018, 11:07 AM
HCI2000SS's Avatar
It's hard to say, and depends on several factors, but usually having it locked will produce higher numbers
Old 08-18-2018, 01:40 PM
Maxwnn1234's Avatar
Okay ill see, he was saying over 500 hp will be easy and with p&p heads it'll make 30-50 plus hp making 550ish
Old 08-18-2018, 02:01 PM
HCI2000SS's Avatar
Yeah I don't see it making 550 rwhp with a stalled auto but you never know
Old 08-20-2018, 11:40 AM
"I MAID THEESE"
Mavn's Avatar
I see 440-450 RWHP . no way in hell you're getting close to 500, let alone 550.
Old 08-20-2018, 08:42 PM
brandon6.0's Avatar
It should be around 500rwhp. Around 650 on the gas. Should run like hell!!
Old 10-21-2018, 07:15 PM
black00TA's Avatar
I wouldn’t think an ls2 is going to do over 500rwhp with an auto, but hey what do I know. Post the numbers!
Old 10-21-2018, 10:12 PM
Mazzenger's Avatar
It might do 550 at the wheels with a 100 shot of spray, but not a chance naturally aspriated.
I agree with Mavn...440 to 450 rwhp naturally aspriated.
Old 10-22-2018, 04:16 PM
"I MAID THEESE"
Mavn's Avatar
SOOO whatd it make ?
Old 10-22-2018, 08:19 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
I think a lot of the dyno numbers will come down to what dyno is used and how the 4L80e was built, the converter and if it's locked on the dyno.
On a honest correctly calibrated DynoJet:
435whp to 450 whp unlocked
440whp to 460 whp locked
525whp-550whp on 100 shot
BTW - quality ported LS3 heads are typically a 25-35 hp gain. Bigger engines might see more. I would wonder about the engine builder's LS experience if he said 50 whp NA for ported heads or 550 whp NA in a stalled auto.
Old 03-09-2019, 11:04 PM
Maxwnn1234's Avatar
so ended up trading the ls2 for a ly6 and upgraded the cam to a stage 4. Still assembling it right now and should be finished by May.
Old 03-12-2019, 04:39 PM
thunderstruck507's Avatar
Agree with the guys saying ~440rwhp N/A, that's the ballpark I'm in with my car.
