F13/header numbers inside!
Old Jan 13, 2005 | 02:43 PM
smacz28's Avatar
Those numbers suck........J/K What should that run in the 1/4 if this guy can drive??? I need a cam in my Hawk or Z06 now
Old Jan 14, 2005 | 03:39 PM
Kalijah98z's Avatar
Originally Posted by Candy
Good to see you got the cam in, nice number. Did they say why they thought you were max'n out your stock injectors? Just curious because we have started hearing this alot lately and we have never ran into this issue at 400 rwhp.
Allan made more power than that with my motor and he said nothing about the injectors being maxed out. That does sound wierd?
Old Jan 15, 2005 | 08:33 PM
AINT SKEERED's Avatar
Mine made 420hp and 405 tq through the 12 bolt and 4.30 gears . stock 26 lb injectors and tuned to 13.5/1 a/f on allens Dyno . No signs of a fuel problem either and we pulled it to 6800 every pull. peaked around 6400 rpms
Old Jan 16, 2005 | 05:41 AM
Bluehawk27's Avatar
Thats weird,
While you do have heads and a ported TB, you have smaller injectors than mine. I wonder if a few of us could have gotten smaller or a bad batch of injectors in our cars. I also think my clutch is about to give out. Your 12bolt and 4.30 gears arent helping ya out either. I'm gonna go ahead and Port my TB and get some larger injectors and see if that doesnt do the trick.
Old Jan 16, 2005 | 09:25 AM
John02SS's Avatar
Do you mean 12.5 or did you guys dail it in lean. Mine make more power that lean, but I was scared to set it there for the street. Thanks bud!
Old Jan 17, 2005 | 02:14 AM
pdd's Avatar
pdd
not bad at all
Old Jan 17, 2005 | 07:55 AM
Black02SS's Avatar
Originally Posted by Bluehawk27
how does it look familiar?
My car does the same thing.
The blue graph is with my FM11(114+4) and TEA Heads, the red is 224(112+0) and TEA Heads.
Old Jan 18, 2005 | 12:04 AM
BLASTER's Avatar
So you lost power going to a FM11 over a 224?
Old Jan 18, 2005 | 12:43 AM
LS1_PNYTAMR's Avatar
damn sure hope not?!
Old Jan 18, 2005 | 02:44 AM
jrp's Avatar
jrp
SN95 Director
Old Jan 18, 2005 | 04:01 AM
pdd's Avatar
pdd
how the hell is that?
Old Jan 18, 2005 | 04:29 AM
  #32
Black02SS's Avatar
We don't know. The only change in my car was the cam swap, LS6 to 78mm LSX intake(Made 5hp on another car), Mac headers to Flowtechs and a Hooker Catback from True Duals. We thought it was the springs so I swaped them out and that didn't help either.
I have since put my setup close to where it was before. I removed the LSX intake, put a set of Pacesetters on and back the True Duals. I am hoping to get the car dyno'd in the next few weeks. But yea, even with that setup, I lost power over my 224 and it didn't make NEAR as much as I had expected with the TEA heads.
Old Jan 18, 2005 | 07:55 AM
  #33
Thats odd , although the 224 is a great little cam.
Old Jan 18, 2005 | 08:10 AM
  #34
Black02SS's Avatar
Yea, its very odd and noone seems to know why. Or the fact it didn't make any power past 6100.
Old Jan 18, 2005 | 07:07 PM
  #35
ulySSes's Avatar
ttt...
Old Jan 18, 2005 | 07:51 PM
  #36
SLowETz's Avatar
Odd. Seems like there has to be something else going on. Was this a monitered tune(IE: AutoTap/ TechII etc.?) Is it possible that you've got some weird condition that isn't allowing proper injector pulse widths/rates? Sh!tty gas lately? Just seems like 111% DC, 12:9:1 A/F, & 27-9* w/that setup means something(relatively simple)is holding it back. What's the FP look like @ WOT?
While(I realize)I'm running heads, I pulled 436/416 w/a smaller cam(F11), 29*, and 12:5:1 A/F(through a 12 bolt/4.56's/slicks), with no DC issues.
No pro here... just some thoughts....
Keep us posted.... Good luck!
Old Jan 18, 2005 | 07:53 PM
  #37
Nickn20's Avatar
what did you log your duty cycles with?
Old Jan 18, 2005 | 08:13 PM
  #38
Nickn20's Avatar
I will do some math for the people that think this is impossible.....
when comparing duty cycle to hp and AFR you need to use uncorrected numbers his were 409 rwhp(colder weather means more hp which means more fuel!) I beleive, which equates to 409/.85 to get the 15% horsepower loss and fwhp is ~481 now, most LS1s drop to about 55 psi fuel pressure at WOT due to thier intank regulators, which lowers the injectors from 28.8 to 28.0x big deal.
So at the BSFC of .5 where a NA engine typically runs, the horsepower at 111% duty cycle is calculated hp is 498, so we are off by about 17 hp, so we are pretty close to what is actual, that could easily be covered by being off a psi in fuel pressure, or a few hundreds in BSFC or a few % in drivetrain loss....... hope this helps some people, out.
I will also state yes these injectors can do a lot as far as HP wise, but they are completely out of control in the 400-420+ rwhp range.
Old Jan 18, 2005 | 09:22 PM
  #39
Black02SS's Avatar
Not to hi-jack his thread, but what is the ICL and LSA of your cam? My FM11 didn't make good numbers at all.
