LS2 intake results on a cam only Vette.
Old Mar 6, 2005 | 12:09 AM
Mike TexaSS's Avatar
8 Sec Tuner
Default LS2 intake results on a cam only Vette.
1999 FRC Vette.
Custom cam
headers
Ls6 intake
Z06 exhaust.
370 RWHP
365 RWTQ
After a LS2 intake, and LS2 90mm TB and tuning.
380 RWHP
370 RWTQ
All for the price of just the FAST intake.
Old Mar 6, 2005 | 01:33 AM
pdd's Avatar
pdd
not bad
Old Mar 6, 2005 | 09:29 AM
V8er's Avatar
Has anyone tested the flow on the LS2 MAN + TB vs the FAST 90mm parts? Since the LS2 stuff is less expensive it is quite attractive, but I am looking for maximum gains and would be willing to pay the extra for the FAST if it makes more power
Old Mar 6, 2005 | 09:33 AM
V-10 Killer's Avatar
What all did you have to adjust in your tune to gain with this intake? Or was it just adjusting for the new TB?
Old Mar 6, 2005 | 09:50 AM
LS1_PNYTAMR's Avatar
i had heard that that volume of this intake was killing the lowend tq and even hurting hp on cam/heads ls1's... would like to know if maybe u did anything different that may have helped your car do better, they were all saying in the ls2/ls7 section that maybe this intake was for 374 ci and bigger ls1's. congrats!
Old Mar 6, 2005 | 10:20 AM
FastBlackTA's Avatar
and people told me I was wasting my time installing a dp system on my ls2
www.nd.edu/~caschenb/dpnitrous/ls2
Old Mar 6, 2005 | 11:23 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
I question how much of the gains you saw simply came from the tuning?
If this was a true intake/TB test, it should have been tuned before the swap and after the swap for a more "scientific" comparison. I understand that you were more concerned with the final results and I'm not looking to be a "neg" here or anything, just calling it the way I see it.
Most of the other LS2 intake tests (which were more aimed at actually testing the intakes) have showed less than stellar results. Also, the move to a larger MAF would have given the LS2 combo another edge.
Bottom line, I think the jury is still out on this intake. Time permitting, I might have a chance to test it when I finally get to the dyno with the 62 cc 225's. I will share my results of that testing assuming I can make it happen.
Tony M.
Old Mar 6, 2005 | 12:37 PM
silverbeast's Avatar
I have to agree with Tony.Hot Rod did a test in this months issue and the ls2 intake LOST horsepower over the ls6.They lost 8 hp and 16 lb-ft of torque.Something to think about.
Old Mar 6, 2005 | 01:41 PM
bad0211secws6's Avatar
what he said
Old Mar 6, 2005 | 06:45 PM
8 Sec Tuner
Tony the car was tuned before and after. And the dynos were done within 1 hr of each other.
Old Mar 6, 2005 | 07:07 PM
D Rock's Avatar
Can I please see a dyno graph?
Old Mar 6, 2005 | 09:39 PM
NVR4GET's Avatar
This is my car this was done through stock Maf unported with screen. The car was already tunned. With the ls6 tune it picked up 8 rwhp more then the ls6 and the A/F dropped around .3 to 12.7. Mike brought the A/F back up the 13.0 and gained 2 more rear wheel horse power. With the ls6 intake the car's A/F was 13.0, This shows that the ls2 intake is better then the ls6. I am glad that I didnt waste my money on the stupid looking Fast intake.
Matt
MODS: LS2 intake, LS2 TB, 3 1/2 year old TPIS headers, Custom cam, cold air intake, Z06 exhaust, stock heads untouched other than the comp 921 springs and push rods, and Custom G-force tune.
Old Mar 7, 2005 | 01:17 AM
5w20's Avatar
time to get a crank pully
Old Mar 8, 2005 | 12:58 PM
triumphman's Avatar
Nice but you would have been happier with the tpis ls-6 oval or the fast 90 mm, the ls-2 intake is not a good piece.
Old Mar 8, 2005 | 01:05 PM
Vortech5300's Avatar
The car A4 or M6?
Old Mar 8, 2005 | 01:31 PM
kickassT/A's Avatar
m6. all frc's are
Old Mar 8, 2005 | 02:10 PM
xfactor_pitbulls's Avatar
Originally Posted by Mike TexaSS
1999 FRC Vette.
Custom cam
headers
Ls6 intake
Z06 exhaust.
370 RWHP
365 RWTQ
380 RWHP
370 RWTQ
I think the baseline numbers look weak. Hell I think both numbers look weak for the work that was done.
Brandon
Old Mar 8, 2005 | 11:41 PM
NVR4GET's Avatar
Brandon
This car make 400 rwhp at MTI's dyno, but G-forces dyno is new so it is reading low numbers. I also do not have a crank pully and The car is tunned for a dry shot of nitrous. That is another 15 to 20 rwhp there, so it would make around 395 - 400 rwhp on G-force dyno, and 410 - 420 rwhp on MTI's dyno.
Matt
Old Mar 9, 2005 | 02:49 PM
Mr Powell's Avatar
And guess what.. if you think its weak bring a cam only 6-spd Vette down here and come get some.. I guarntee you will be shocked when you see the numbers this car clicks off on motor...
