TSP Magic Stick v.3 Dyno
This sux, hopefully I can find out what is wrong, well at least my tuner gave me dynotunes for life.
I'VE TUNED SEVERAL CARS AND SOME LIKE TO RUN A LITTE RICH.
Another BIG point I wanted to make is that you guys that are dyno tuning on the shop's dyno that sold you the parts, you MAY not be getting everything you think you are getting. This is a big deal in the streetbike world. You take your ride to a shop and they promise you X amount of HP for X amount of dollars, the customer wants that HP no matter what, and he WILL get it, no matter what. All you guys making the big HP on Futral's dyno with Futral's cam and tuning, have you ever dynoed on another dyno besides their's just for comparison? Or even TSP's for that matter. No doubt these guys are in the market to sell parts and more importantly HP. Every one of these vendors promises the big gains with "their" parts so...take advertisements and dyno numbers on "their" dynos with a grain of salt.
If im making 383 RWHP and 350 RWTQ SAE corrected there is definatley something wrong with my car...
The weird thing is i beat my friends 402 rwhp TA when i was untuned by half a car. The car feels alot beter now though, its all over the place at 6k+ and im running MT ET street radials.
BTW I was at G-Force today and they dynoed a car that had heads and a 224/226 something cam, it came in making 387hp and after they tweaked it, it was at 394hp. They did not build this car, it was just a revision to someone else's tuning but the point is, it didn't make 400hp with heads and cam so.. It appeared to have all the bolt ons that I could tell except maybe a pulley.
Why?
Airflow. The stock LS1 heads don't flow well enough at the upper rpms to support higher horsepower. Open the intake for a 224 duration, or a 237, it doesn't matter, only so much air per second can flow at a certain volume and certain velocity. I'm not saying a cam of that size is designed for a 400+cid engine, but it needs heads that flow a certain cfm at a certain velocity to make a certain horsepower. Usually, you need a bigger bore to get that, or something like the AFR 225s...
Bottom line, get some better heads on that thing. AFR 205s don't even flow enough for the air of a 346cid engine over 5k for it to be worthwhile for a 237 cam to replace a 224 cam. Of course, a 224 cam and 205s are gonna flow a lot more air, and thus make more power than a 237 with LS1 heads. The MS3 & 205s probably won't make much more, because I've seen how the G5X3 doesn't make a whole lot more than the smaller cams with similar setups. G5X3 of course has 234 degrees intake duration.
Oh, and all of that pertains to the Dyno. The track is an entirely different beast...
Actually I made 411 with stock 241 castings with all the mods in my sig minus the n2o. I could.ve made more if I would have went to the limiter but I cut it off at 6200. Limiter is 6800
If anything, it proves that if you give the MS3 a little bit more airflow, it responds by giving you a few more ponies.
Most people who slap T-Rex's don't see any more than 400rwhp either. Of course, a TR224 that attained 400rwhp isn't going to beat it at the track, but it will be better for the street. Once you open up the engine a bit, the TR224 becomes a bit of a bottleneck compared to a larger cam, but that takes quite a bit of opening.
some very good points to think about.
i need to get me a dyno out here to see.
hmmmm
and on the record when i said more power, i meant tq......
Feel free to call or e-mail me at trevor@texas-speed.com with any questions or concerns. The key with any cam swap is selecting the right one that is going to work well with YOUR setup and YOUR goals in mind.
WS6FirebirdTA00 - I've sent you an e-mail. I would like to know what happened.
Trevor
Texas Speed & Performance
